Screaching sound at biting point
Bon go north
Post by Bon go north » Wed Aug 15, 2007 4:13 pm
I have a manual gearbox bongo and at the moment, when I change gear and reach the biting point, there is a screaching sound until the clutch is all the way back up. Once the clutch is up there is no sound whilst driving. This happens going up and down the gears and there is no gear where the sound is worse. Is my clutch on the way out Hellllllllllllllllp!!
Andy
westonwarrior
Post by westonwarrior » Wed Aug 15, 2007 4:33 pm
I realy have no idea but a thrust bearing springs from the depth of my memory.
Bon go north
Post by Bon go north » Wed Aug 15, 2007 4:38 pm
Any idea on a remedy??
Post by francophile1947 » Wed Aug 15, 2007 4:55 pm
Totally agree - thrust bearing.
Unless clutch is new, best to replace the lot, instead of having to pay two lots of labour when worn out.
westonwarrior
Post by westonwarrior » Wed Aug 15, 2007 5:02 pm
at least my memory somtimes works :lol:
Post by Ian » Wed Aug 15, 2007 5:38 pm
I have a Clutch Kit in stock if you need it.
Bon go north
Post by Bon go north » Wed Aug 15, 2007 7:47 pm
Many thanks. I see that the kit is £240, any ideas on estimated labour cost? Also, any ideas on another problem. When I drive the bongo (to work in the morning for example) there seems to be a smell which comes through the vents. When I stop the bongo, if I lift the bonnet I can smell the smell more easily from the bonnet end. Any idea? Thanks for your help.
westonwarrior
Post by westonwarrior » Wed Aug 15, 2007 7:50 pm
What does it smell of ?
Bon go north
Post by Bon go north » Wed Aug 15, 2007 7:56 pm
Not sure what it smells of, it doesn't have the air conditioning smell. It's like a hot sort of smell didn't know wether it might have something to do with the heating matrix????? I'm not that well up on the ways of the bongo.
Post by mikeonb4c » Wed Aug 15, 2007 8:29 pm
There was some talk on BF about removing and cleaning up the heater matrix (I think it was, it was the heater/blower gubbins anyway) as it can get really crudded up, which impairs its efficiency (overwork the motor?), and presumably could cause smells too. Have a Search on BF using words like 'blower' etc
good luck 8)
Bon go north
Post by Bon go north » Wed Aug 15, 2007 8:37 pm
Thankyou for all your help. It is worthwile being a member for info like this. The heater matrix/blower sounds like quite a likely source of the smell. Many thanks
motorwizard
scretching sound from clutch
Post by motorwizard » Wed Aug 15, 2007 8:51 pm
My son in Law has a Golf racing car, He had a loud scretching sound from the clutch whilst the pedal was down. After deciding it definitely was the clutch we took it out and found that two of the drive straps in the clutch cover were broken. There are three metal strips between the cover and the rubbing plate which hold the rubbing plate in place, when the straps were broken the rubbing plate is free to move.
dandywarhol
Post by dandywarhol » Wed Aug 15, 2007 9:59 pm
These 3 straps actually take all the drive between the engine and gearbox - hard to believe they look so flimsy. It's no wonder it was screeching! They probably broke when he "dumped" the clutch in racing car fashion..............
BongoedIslander
thrust bearing
Post by BongoedIslander » Wed Aug 15, 2007 10:30 pm
definitely ..clutch thrust bearing ..agree with the advice given on previous posts . .having gone to the trouble and expense of taking your box down..renew your cluch assembly too ..the screeching is caused by the dry bearing as you disengage the clutch . .[ putting in the cluch pedal] :cry:
