Unpredictable starting
casscasscass
Hi guys I seem to have no notion as to why when
I turn the key, wait for light to go off, go to turn final bit and all it does is go 'click'. This is happening daily now and most time it finally turns over after about 7-10 turnovers. Its not just the first start of the day either. And there is nothing but a 'click' no wirr or chug nothing just click. I was thinking starter motor but could it be intermittant electric fault ???(not that I really know much about these things).....thanks Cass
pippin
cynfal
casscasscass
moonshine
I had the same problem until recently. All I did was remove the starter motor, which wasn't that difficult, dismantled the solenoid, and cleaned the contacts. Bongo starts first time every time now, but I know it's only a temporary cure as the contacts were well worn. Soon, when I have found out what model of starter motor I have, I will be contacting this company
http://www.nationsautoelectric.com/densoparts.html
to get some new contacts, and then I will replace the old ones.
