engine oil
Duncan
engine oil
Post by Duncan » Sun May 20, 2007 1:18 pm
Hoe much oil should my van take, 2.5 td auto
waycar8
Post by waycar8 » Sun May 20, 2007 2:13 pm
6 litres :wink:
Post by mikeonb4c » Sun May 20, 2007 8:57 pm
I have a nagging feeling you have to add 0.7 of a litre to that figure when changing the oil filter. Can anyone confirm? :?
Post by francophile1947 » Sun May 20, 2007 9:04 pm
Confirmed Mike - 6.7 litres including filter, 6 litres without.
waycar8
Post by waycar8 » Sun May 20, 2007 9:51 pm
hmmmn.......... when i had my oil changed including the filter, the mechanic told me it took 6 litres, and i checked it the other day and its still on the max mark!
and i trust the mechanic, hes the brother in law
Colin Lambert
Post by Colin Lambert » Sun May 20, 2007 10:18 pm
6.7 litres including filter. 6.0 litres without.
Duncan
Post by Duncan » Sun May 20, 2007 10:21 pm
yep i did change the filter and , 6 lts did not fill it,
so I need more oil.
Post by mikeonb4c » Sun May 20, 2007 10:33 pm
Have you checked it since waycar, in case he had checked it before the system had settled. I seem to recall getting dipstick on the max mark when I changed by oil and filter and before I reached 6.7 litres. My memory is vague, but I'm pretty sure I ended up putting in 6.7l or thereabouts, maybe because the level settled after a bit. I doubt it will self-destruct if only 6l in it though!
Mike
daveblueozzie
Post by daveblueozzie » Sun May 20, 2007 11:40 pm
I have just taken my bongo to my garage where i bought it to have a top up of oil it showed half full / empty on the dipstick , he said the marks are for top up reference ,he showed me it only needed 1/2 litre,
Lost without my Bongo.
waycar8
Post by waycar8 » Mon May 21, 2007 6:44 pm
doh :oops: .............yes it did take 6 litres of oil.... i also bought some grease lighting oil additive which got put in at the same time :oops:
sorry duncan for the duf info :cry:
brorabongo
Post by brorabongo » Mon May 21, 2007 9:12 pm
Used over 6L when changed with filter. Used magnatec not cheap as have to buy two around £25 each (4.5L), but I noticed a quieter engine, and now able to cruse through the village at 30mph in fifth without that horrible droning/labouring noise as before.
ボンゴの激怒 pictures
waycar8
Post by waycar8 » Mon May 21, 2007 9:20 pm
yours a manual gearbox?
brorabongo
Post by brorabongo » Mon May 21, 2007 9:22 pm
yep
ボンゴの激怒 pictures
