Stuck in gear, fans on, no glow plug light.
Gavinstjohn
Post by Gavinstjohn » Tue May 21, 2024 4:46 pm
Hi all, my 1995 2.5 td Bongo is sparadically working. Sometimes I get in and it fires up fine, drives perfectly, other times I jump in, the coolant fan automatically comes on, the glow plug light doesn't illuminate and the gearbox is stuck in 3rd. I have done everything I can think of. Has anyone experienced this and managed to fix it?
Thanks Gav.
Re: Stuck in gear, fans on, no glow plug light.
Post by Bob » Tue May 21, 2024 7:43 pm
Welcome aboard.
Not a set of symptoms I'm familiar with, but we may be able to suggest a Bongo Friendly garage near you.
Gavinstjohn
Post by Gavinstjohn » Tue May 21, 2024 7:45 pm
Thank you Bob. I'm near Bridgend, South Wales.
Post by Bob » Wed May 22, 2024 6:34 pm
Owen's Motor Services, Cowbridge, are on the list of Bongo Friendly garages:
https://jmaps.net/owens-motor-services
Gavinstjohn
Post by Gavinstjohn » Wed May 22, 2024 6:37 pm
That's amazing, thank you very much for your reply. I'll contact them tomorrow.
Gavin.
Post by Bob » Wed May 22, 2024 8:19 pm
You’re very welcome, good luck. 8)
sabbir
Post by sabbir » Mon Sep 23, 2024 6:56 am
Gavinstjohn wrote: Tue May 21, 2024 4:46 pm Hi all, my 1995 2.5 td Bongo is sparadically working. Sometimes I get in and it fires up fine, drives perfectly, other times I jump in, the coolant fan automatically comes on, the glow plug light doesn't illuminate and the gearbox is stuck in 3rd. I have done everything I can think of. Has anyone experienced this and managed to fix it?
Thanks Gav.
hi
i am from canada, i have the exact issue, i am unable to find any mechanic that deals with bongo here in canada. did you find out what was the issue with your van? thanks a lot
Gavinstjohn
Post by Gavinstjohn » Mon Sep 23, 2024 7:25 am
Hiya, not quite yet, we are going to change another part which connects to the gearbox, this is being done tomorrow, Tuesday September 24th. I'll let you know the outcome.
Cheers Gav.
sabbir
Post by sabbir » Tue Sep 24, 2024 6:15 am
thanks much appreciated.
sabbir
Post by sabbir » Sun Sep 29, 2024 4:42 am
did you figure out anything yet?
Gavinstjohn
Post by Gavinstjohn » Sun Sep 29, 2024 10:51 am
Hiya, so, reconditioned gear box fitted to the van (did not fix it) there's a gear selector piece which fits to the gearbox, that was done on Thursday 26th, so far so good but it's still early days.
That piece has been changed.
sabbir
Post by sabbir » Mon Sep 30, 2024 1:47 am
so your gear selector was faulty or the actual gear box had issues?
Gavinstjohn
Post by Gavinstjohn » Mon Sep 30, 2024 8:19 pm
At the moment it's looking like the gear selector.
sabbir
Post by sabbir » Tue Oct 01, 2024 5:27 am
it fixed your glow light and fan ?
Gavinstjohn
Post by Gavinstjohn » Tue Oct 01, 2024 7:28 am
Hi, at the moment yes, the fault was sparadic, the van could work for a few days and then not. As it's only been a few days i don't know if the part swop has cured thr problem yet.
