Heat/air display won’t turn on!
Bonny Bongo
Post by Bonny Bongo » Tue Jun 13, 2023 6:29 am
Hey… we are new bongo owners here and needing help to sort the heater/air system on the dashboard. It just won’t turn on and I’m not sure which and where to check the fuse? Sorry if this is a really silly request of help but this group had been advised to contact :)
Re: Heat/air display won’t turn on!
Post by Ian » Tue Jun 13, 2023 7:42 am
The fuse is under the bonnet, in the plastic box near the main vehicle battery. Flip it open and look for the bank of 6 fuses. The one for the heating is second ffrom the right, 30amp.
Post by g8dhe » Tue Jun 13, 2023 8:41 am
The actual control panels are powered by this fuse
The front fan, rear fan and compressor clutch are all in the fuse panel Ian mentions above.
