Rough idle/stall when warm
mwalshuk
Post by mwalshuk » Mon Mar 27, 2023 10:15 am
I've had an issue for the last couple of months that when driven for a while my bongo will start to struggle and sometimes stall when breaking to a stop in Drive. If I put the gear into Neutral or Park then the revs increase a little and it mitigates the problem. Obviously when breaking for junctions and looking to quickly move away this isn't a viable option.
Has anyone experienced this? If so any ideas what I ask my garage to look at?
To confirm when cold the revs stay higher and it doesn't occur.
Thanks in advance,
Michael
Re: Rough idle/stall when warm
Post by g8dhe » Mon Mar 27, 2023 11:00 am
Can you confirm which engine ?
A common cause for all engines is a blocked fuel cap vent, if you take the cap off and pull apart the spring loaded vent and give it a clean it may be the problem the caps are similar to below;
mwalshuk
Post by mwalshuk » Mon Mar 27, 2023 11:13 am
Hi Geoff,
Thanks for the quick reply.
It's a V6 2.5L Petrol. I do have an LPG conversion and the problem is consistent on both fuels. Not sure if that rules out the fuel cap hypothesis?
Michael
Post by g8dhe » Mon Mar 27, 2023 11:54 am
In that case I would assume it does rule it out ;-)
I'm not a mechanic but would myself take a look at other common things, air filter and ignition system as its a V6 check the spark plug wells for oil gathering in them from a loose cylinder head bolt(s) or a leaking gasket.
mwalshuk
Post by mwalshuk » Mon Mar 27, 2023 3:18 pm
I'll check that out.
Thanks Geoff
