Double din stereo removal
hawko
Post by hawko » Wed Sep 14, 2022 9:53 pm
Hi all,
So ive finally decided its time to change out the Japanese stereo for something that will give me more than R2 :lol:
So, i've got the two plastic side panel parts off but dont really see any obvious places you'd slide removal keys into, or in my case a selection of thin screw drivers.
Can anyone point me in the right direction?
I did find this other post around the same issue, but not sure if i need to dig into removing bits like that describes if there should be proper removal key holes im meant to use?
viewtopic.php?t=57798
Any pointers very much appreciated!
I'll likely have more follow up questions once i get it out but lets start here :)
2004 2.0L Petrol Auto, tin top in grey
hawko
Re: Double din stereo removal
Post by hawko » Wed Sep 14, 2022 10:01 pm
Oh and heres a pic of the unit i have if thats any help at all...
Post by g8dhe » Thu Sep 15, 2022 8:56 am
The mech diagrams show the normal spring clips top and bottom each side http://www.lushprojects.com/bongopartsm ... 1of03.html
hawko
Post by hawko » Thu Sep 15, 2022 11:36 am
g8dhe wrote: Thu Sep 15, 2022 8:56 am The mech diagrams show the normal spring clips top and bottom each side http://www.lushprojects.com/bongopartsm ... 1of03.html
Thanks for that, gives a good view of whats there. So do you think I need to actually remove those side plates, or is there meant to be some way for me to unclip them to release it?
Post by g8dhe » Thu Sep 15, 2022 11:52 am
No use a release tool or small screwdrivers to press the spring bits in top and bottom each side parts 66-AC5.
