Roof Motors Advice - Bongo 2.5TD 1999
JF117
Re: Roof Motors Advice - Bongo 2.5TD 1999
Post by JF117 » Mon Jul 04, 2022 3:14 pm
g8dhe wrote: Mon Jul 04, 2022 3:08 pm Yes that is definitely a case of a newer model tent having been put on an older roof :-) Been there done that myself! Ended up being able to exchange it with someone who had the reverse combination so we both ended up with the right sizes!
That doesn't however explain the beeping continuing, but I suspect that who ever worked on it before may have played with all the parts involved and hence the limit switch is one way or another not tripping or telling the computer its reached full height!
I'm also starting to think that I should have got the newer style struts as I'm currently looking down at my originally removed strut and its measuring in at approx 999mm.
So is it this?
https://www.sgs-engineering.com/gsc3128 ... roof-strut
At this point I'm 120£ down on 2x pairs of struts and probably going to go after another set... :shock:
Post by g8dhe » Mon Jul 04, 2022 3:20 pm
A bit more complicated than this, the older roof cantilever sliders that do the raising are different from the later Aero design as they (the aero ones) had to reach 3" higher in the same length of travel, but in the lowered position couldn't be any longer than the original ones in order to fit on the roof of the Bongo, hence the gas struts are different lengths but so also is the cantilever section its actually quite ingenious when you study how the roof is raised how they do it.
JF117
Post by JF117 » Mon Jul 04, 2022 3:32 pm
g8dhe wrote: Mon Jul 04, 2022 3:20 pm A bit more complicated than this, the older roof cantilever sliders that do the raising are different from the later Aero design as they (the aero ones) had to reach 3" higher in the same length of travel, but in the lowered position couldn't be any longer than the original ones in order to fit on the roof of the Bongo, hence the gas struts are different lengths but so also is the cantilever section its actually quite ingenious when you study how the roof is raised how they do it.
What should I do? :shock:
If I was to hazard a guess at what's happened here, using the knowledge you've provided, I'd say everything seems consistent with the fact it's an Aero AFT?
I spoke to Adrian at Japan Direct - Bury over the phone and he asked me to measure the following to which he also said it should be about an inch short of the end of the rail.
I'm going to phone SGS engineering and see what can be done, the only explanation in my head is that the struts are too short and it needs an extra lift... :?
Post by g8dhe » Mon Jul 04, 2022 3:57 pm
Not sure its possible to diagnose remotely, I suspect you really need to compare parts:- Tent, Roof itself, sliders, cantilever arms, gas struts and see what is what. I guess you must have an Aero tent, but maybe its the shorter gas struts that aren't allowing it to go fully up, or its mismash of parts before you even got it if someone didn't understand that there are two sizes.
JF117
Post by JF117 » Mon Jul 04, 2022 5:12 pm
g8dhe wrote: Mon Jul 04, 2022 3:57 pm Not sure its possible to diagnose remotely, I suspect you really need to compare parts:- Tent, Roof itself, sliders, cantilever arms, gas struts and see what is what. I guess you must have an Aero tent, but maybe its the shorter gas struts that aren't allowing it to go fully up, or its mismash of parts before you even got it if someone didn't understand that there are two sizes.
I would say that at one point the previous owners did not have this problem. It only started happening just after we bought it, so with that assumption in mind, there must be a way to fix it.
There are two options:
Re gas my originally purchased adjustable gas struts to the same force as the second set and see what happens or just buy a third set which are designed for the Aero AFT and see what happens.
:cry:
Hazzobongo
Post by Hazzobongo » Mon Jul 04, 2022 6:09 pm
Mines also a 2.5 diesel with AFT and last weekend was the first time since we tried it out when we bought it that we used the roof and its the same as yours regarding the bleeping continuing once the roof is fully up and ours was full up as the tent portion was taut.
When we started the engine on leaving the campsite it wasn't bleeping any more and only began bleeping after pressing the unlock button and then the lowering button but it stopped when the roof was fully lowered.
Could be just a lack of use imo and whatever triggers the beep noise was stuck and so it continued.
JF117
Post by JF117 » Mon Jul 04, 2022 7:09 pm
Hazzobongo wrote: Mon Jul 04, 2022 6:09 pm Mines also a 2.5 diesel with AFT and last weekend was the first time since we tried it out when we bought it that we used the roof and its the same as yours regarding the bleeping continuing once the roof is fully up and ours was full up as the tent portion was taut.
Do you know if your struts are original and if so what's the code/serial # on them?
if they are [S52H 56 94C] and you know for a fact you have a AFT, then that's probably how I should have replaced mine.
Heres a picture of my original strut side by side the SGS Engineering GSV10-450 adjustable strut.
The GSV10-450 adjustable was too strong but the bleeping noise did stop. So I'm not sure whether to go for SGS's GSC3128 / https://www.sgs-engineering.com/gsc3128 ... roof-strut
Hazzobongo
Post by Hazzobongo » Thu Jul 07, 2022 7:20 pm
Sorry mate I couldn't tell you for certain if they're the originals but considering its only been in this country three years and with 60k miles I assume they're all original parts, I can raise it in the morning and check for the numbers if you like, I'll post the results afterwards.
JF117
Post by JF117 » Thu Aug 04, 2022 5:23 pm
Hazzobongo wrote: Thu Jul 07, 2022 7:20 pm Sorry mate I couldn't tell you for certain if they're the originals but considering its only been in this country three years and with 60k miles I assume they're all original parts, I can raise it in the morning and check for the numbers if you like, I'll post the results afterwards.
I ended up buying SGS's AFT Aero aka new style struts, so that I could try them out and see, but they still haven't arrived yet.
Hazzobongo
Post by Hazzobongo » Sat Sep 03, 2022 7:42 pm
My apologies again, something must have came up and distracted me at the time and I completely forgot to take a look, probably due to holiday season as both myself and my son have been taking breaks away in the van, him at weekends and us during the week as with the glorious climate change we couldn't resist lol.
Hope you got it all sorted by now.
Onegoldenearth
Post by Onegoldenearth » Wed Apr 10, 2024 6:40 pm
Did you find a solution in the end? I am looking to replace my struts and my van is a 1999 diesel with the same tent as yours and the struts have the same code on them, S52H 56 940.
Post by g8dhe » Wed Apr 10, 2024 10:05 pm
SGS do all the different struts and I think are the only suppliers in the country!
https://www.sgs-engineering.com/car-boo ... azda/bongo
Onegoldenearth
Post by Onegoldenearth » Wed May 01, 2024 9:45 pm
I rang SGS and provided them with the measurements and part number and they do not sell a strut that matches dimensionally or have a listed alternate of the shelf part number. It would seem these two bongo's sharing the same roof and tent type visually and the same damper part number S52H 56 940 aren't cobbled together but unique to this period model. I've checked all the usual sources from sellers from abroad partsouq, Amayama and Yoshi parts and this differing damper part number does exist for this age vehicle post September 1999. So there must have been a deviation in AFT design between old and new at face lift where I sumise they used old and new parts together with a unique strut to make it all work.
In the end all SGS could could offer was a one off made to measure adjustable pressure strut. However they have no idea of the weight of the roof or the force involved in opening and closing the roof so would be guessing as to how much pre-charge is required. Also when asked only they can re-charge these struts, so if they set the pressure wrong I would have to send back at my expense to be re-charged. Also these struts are not returnable as they would be cut to length and threaded to take the correct size ball joint. Some more help is required here if possible please to ensure SGS get this right first time.
JF117
Post by JF117 » Tue Mar 25, 2025 11:22 pm
JF117 wrote: Thu Aug 04, 2022 5:23 pm
It's actually crazy to think that this was almost two and a half years ago.
Anyway, I eventually got them and had them replaced.
It took three attempts but the correct fitment was the NitroLift Mazda Bongo 2nd Edition Camper Van Roof Gas Strut [GSC3128].
If I remember correctly, I had them fitted down in DRA services, south croydon around June / July 2023 and the beeping even stopped, was so happy about that. :lol:
