Leisure battery not charging on hook-up
barrysheene
Post by barrysheene » Mon Aug 22, 2022 10:53 am
Hi All
Sorry if this topic has been covered before. My leisure battery drained overnight while I was on hook-up, I had nothing running apart from my 12v fridge. I thought that hook-up was supposed to charge the LB?
Re: Leisure battery not charging on hook-up
Post by g8dhe » Mon Aug 22, 2022 1:06 pm
Welcome aboard!
All depends on what has been installed in the conversion!
What sort of installation do you have, any photo's, is it a named conversion ?
These are typical systems that would have an inbuilt charger/12v supply;
However many installations even from some of the smaller converters are little more than DiY jobs, with control panels from eBay and the like and very little knowledge of what is needed or how it would be used!
barrysheene
Post by barrysheene » Wed Aug 24, 2022 1:06 pm
Hi Geoff
Thanks for your reply, the conversion is a 321 away, can't see anything like a control panel, we turned the fridge off whilst on the hook up the last couple of nights and the leisure battery kept its charge.
Regards
Dave K
Post by g8dhe » Wed Aug 24, 2022 2:04 pm
I seem to recall that they have some fuses and switches behind the Drivers seat ? Have you checked around there ?
barrysheene
Post by barrysheene » Thu Aug 25, 2022 11:09 am
Hi Geoff
These are the two boxes behind the driver's seat, the one on the left has a constant green light illuminated.
Best Regards
Dave K
Post by g8dhe » Thu Aug 25, 2022 1:13 pm
Yes the one on the left is a 12 volt supply for running and charging the 12 volt battery.
If the Fridge is running from 12 volts and only from the battery then it sounds like either a connection from the supply or the supply itself has failed, you will really need to have a check around with a voltmeter to see what is going on.
barrysheene
Post by barrysheene » Thu Aug 25, 2022 4:26 pm
Thanks for your help Geoff, I'll get it checked over 👍
