How can I protect my new exhaust/catalytic converter from being stolen again??
claireheal
Post by claireheal » Sat Oct 16, 2021 8:13 pm
Hi everyone,
Only had my lovely Bongo (2.5l, V6, 1999) for 2 weeks and someone's stolen a section of the exhaust, I assume for the catalytic converter!
Trying to find a local secure garage to park her in from now on, but that might not be possible.
So, is there an additional cover or alarm or something to make the exhaust/cat more secure, ie harder to steal?!
All suggestions gratefully received.
Many thanks.
Claire :)
Re: How can I protect my new exhaust/catalytic converter from being stolen again??
Post by Bob » Sat Oct 16, 2021 8:56 pm
Hello Claire, warm welcome.
Sorry to hear you've been targeted by those scum. :twisted:
Don't know your circumstances, but if you park on your drive maybe cameras?
Harv
Post by Harv » Sat Oct 16, 2021 10:50 pm
Do a search for catalyst protectors, there are a few products.. A well known one is catloc.co.uk,
Harvey the Pookah is no longer looked after by Richard
Winnie-bongo
Post by Winnie-bongo » Sun Oct 17, 2021 1:54 pm
As you have a pre September 2002 you don't need a cat so can just put a piece of pipe in to replace the stolen cat, as the Bongo should have a non cat test at mot time 🚐
Post by Bob » Sun Oct 17, 2021 3:53 pm
That's good info. :)
claireheal
Post by claireheal » Mon Oct 18, 2021 11:36 pm
Thanks chaps, appreciate your helpful suggestions.
Claire :D
Post by Ian » Tue Oct 19, 2021 9:06 am
However, this i also from the MOT testers guide:
"If a cat was fitted at the time of manufacture then it must be fitted at the time of inspection."
That doesn't mean it has to be tested, just present.
claireheal
Post by claireheal » Tue Oct 19, 2021 12:25 pm
Bob wrote: Sat Oct 16, 2021 8:56 pm Hello Claire, warm welcome.
Hi Bob,
Unfortunately I don't have a drive.
Looking for a lock-up garage locally.
Thanks.
Claire :)
Post by Bob » Tue Oct 19, 2021 5:48 pm
If you find one, and you have an AFT, make sure Bongy isn't too tall to go inside. :wink:
Edit: Just seen your location, we're in Nailsea.
claireheal
Post by claireheal » Tue Oct 19, 2021 9:13 pm
Bob wrote: Tue Oct 19, 2021 5:48 pm If you find one, and you have an AFT, make sure Bongy isn't too tall to go inside. :wink:
Aha, you're not far away there Bob :D
Don't suppose you know anyone with a lock-up garage they could rent to me in Bedminster/Southville area?
Very few around and pricey!
Claire :)
P.S. she's a tin-top, approx 2m high.
Post by Bob » Tue Oct 19, 2021 9:57 pm
Strangely not. :?
As you say, very high demand for such things.
I'm guessing you use Bongy every day, but if not there are are storage places to be had, but a bit further away.
claireheal
Post by claireheal » Tue Oct 19, 2021 10:07 pm
Bob wrote: Tue Oct 19, 2021 9:57 pm Strangely not. :?
Ah well, it was worth asking, just in case! ;)
Not every day, but often enough to need her nearby. The search continues! ;)
Getting new cat fitted tomorrow so will prob park at a friends a couple miles away until I get a garage to rent nearby.
Thanks Bob.
Claire
Winnie-bongo
Post by Winnie-bongo » Wed Oct 20, 2021 3:33 pm
Ian wrote: Tue Oct 19, 2021 9:06 am However, this i also from the MOT testers guide:
I just asked DVSA this very question Ian
Alkers
Post by Alkers » Thu Oct 21, 2021 11:35 am
I actually saw on instagram where a garage had made a steel frame around someone's exhaust to prevent the cat from being stolen again. It was a bongo and all - looked horrific but would probably work
cwilliams255
Post by cwilliams255 » Mon Nov 01, 2021 3:00 pm
My drinking water tank is pretty close to the cat under the step, it has 3mm steel frame, it would make removal slightly awkward and I would like to think if they tried they’d nick the tank with the grinder and get 30L of water all over them. How much I expect a bit of water to inconvenience or upset then I don’t know but it would make me feel slightly better :D
