sliding door
turfite9999
sliding door
Post by turfite9999 » Thu Mar 04, 2021 5:09 pm
Hi guys hope you all keeping safe,
Please does anyone know how to test the sliding door contacts on a 1996 bongo please using a multi-meter, or any other methods.
Many thanks in advance
Tony
Re: sliding door
Post by g8dhe » Thu Mar 04, 2021 5:57 pm
You do realise that its a small 8-bit microcomputer controlling it ?
What exactly is the problem your having ?
turfite9999
Re: sliding door
Post by turfite9999 » Fri Mar 05, 2021 11:31 am
Hi Geoff thanks for the reply,
got all central locking working but the soft close not working, does 96 Bongo have soft close? I have changed motor at bottom of door.
Tony
PS do you know where I can get retaining clips for locking rods on sliding door
turfite9999
Re: sliding door
Post by turfite9999 » Fri Mar 05, 2021 11:34 am
Sorry Geoff its a retaining clip for the sliding door exterior handle rod
Re: sliding door
Post by g8dhe » Fri Mar 05, 2021 12:01 pm
Yes provided the door contacts have all 5 positions fitted then it should be soft-close, if it only has the 2/3 door locking contacts fitted then no!
For the small retaining clips speak with BongoSpares is normally best solution or find someone breaking a van locally.
turfite9999
Re: sliding door
Post by turfite9999 » Fri Mar 05, 2021 12:50 pm
Thanks again Geoff
turfite9999
Re: sliding door
Post by turfite9999 » Wed Mar 31, 2021 3:27 pm
Thanks all for your help just trying to get plastic retaining clip for the exterior handle rod without buying the whole handle
tony
