What is this behind front bumper... see the photo.
phillips321
- Junior Bongonaut
Hi all,
Have taken bumper off so I can fix some of the arches with some sheet metal but have come across this unit that looks like it has a fan in it, what exactly is it as it doesn't look like it works at all based on the condition!
Thanks in advance
Thanks in advance
Re: What is this behind front bumper... see the photo.
A siren type of horn, possibly leftover from a previous alarm.
Is this a petrol model? Is there any pipework on it?
It looks a bit like an air pump you would find on petrol cars with a catalyst, its used for making the cat heat up faster to operating temperature.
- Attachments
- 58905E4B-263B-4079-A30B-70CFE2CD4965.jpeg (25.82 KiB) Viewed 7096 times
95 2.5d 4WD AFT
Certainly looks like it.
phillips321
- Junior Bongonaut
Nope this is a diesel model. No pipes or anything going to it.
Hmmm, to be fair i though the Bongo might be a bit old to have something like this but it certainly looks like a secondary air pump.
If that's ruled out then I reckon its some sort of additional horn/siren as said above.
Does any wiring tap into the horn wiring just above it?
You could power it up & see if it blasts out anything in Japanese
95 2.5d 4WD AFT
Well there you go "The Dukes of Hazzard" had a Bongo.
Doesn't bear thinking how the Dukes of Hazzard would have treated a Bongo.
Interesting.
Whats it look like from the other side, where does the ducting run to?
