What is this behind front bumper... see the photo.
phillips321
Post by phillips321 » Fri Sep 11, 2020 7:40 pm
Hi all,
Have taken bumper off so I can fix some of the arches with some sheet metal but have come across this unit that looks like it has a fan in it, what exactly is it as it doesn't look like it works at all based on the condition!
Thanks in advance
Propnut
Re: What is this behind front bumper... see the photo.
Post by Propnut » Fri Sep 11, 2020 10:59 pm
A siren type of horn, possibly leftover from a previous alarm.
nth
Post by nth » Sat Sep 12, 2020 7:35 am
Is this a petrol model? Is there any pipework on it?
It looks a bit like an air pump you would find on petrol cars with a catalyst, its used for making the cat heat up faster to operating temperature.
95 2.5d 4WD AFT
Post by Bob » Sat Sep 12, 2020 8:39 am
Certainly looks like it. =D>
phillips321
Post by phillips321 » Sat Sep 12, 2020 9:21 am
Nope this is a diesel model. No pipes or anything going to it.
nth
Post by nth » Sat Sep 12, 2020 10:04 am
Hmmm, to be fair i though the Bongo might be a bit old to have something like this but it certainly looks like a secondary air pump.
If that's ruled out then I reckon its some sort of additional horn/siren as said above.
Does any wiring tap into the horn wiring just above it?
You could power it up & see if it blasts out anything in Japanese :lol:
95 2.5d 4WD AFT
rita
Post by rita » Sat Sep 12, 2020 10:42 am
Well there you go "The Dukes of Hazzard" had a Bongo.
Post by Bob » Sat Sep 12, 2020 4:23 pm
Doesn't bear thinking how the Dukes of Hazzard would have treated a Bongo. :shock:
Bongolia
Post by Bongolia » Fri Sep 18, 2020 9:41 pm
Interesting.
Whats it look like from the other side, where does the ducting run to?
