starter battery for 2.0 petrol
knpenny
Post by knpenny » Sun May 20, 2018 1:44 pm
Hi all, just wondering if anyone knows the correct power of battery for the 2.0 petrol as i think mine is a bit weak.
mine is 450 60ah, its a bit weak on first start in the mornings but after that it starts instantly. Matbe battery on the way out(not holding charge)?
thanks as always in advance :D
Bongology, the study of all things bong. The bongologist. :shock:
Re: starter battery for 2.0 petrol
Post by Bob » Sun May 20, 2018 5:03 pm
Not sure what the spec is for the 2 ltr petrol, but assuming the tray is the same I'd look to fit a 95ah one for a diesel.
That will give you plenty of oomph for not a lot more money.
Tayna have provided me with a few batteries, or there's often a discount code for Euro Car Parts, a Google search often finds one. :wink:
knpenny
Post by knpenny » Sun May 20, 2018 6:39 pm
So if i install a battery with more Ah and cca it wont damage the vehicle? Thats basically what i'm worried about :? thanks for the response bob
Post by Bob » Sun May 20, 2018 7:22 pm
definitely won't do any damage by fitting a higher capacity battery, just gives you a bit more stored lectrickery for when needed. 8)
Post by g8dhe » Sun May 20, 2018 7:29 pm
I always suggest this one Bosch S4 335 (the last 3 digits can vary there are several that fit) https://www.google.com/search?q=Bosch+S ... utf-8&aq=t
knpenny
Post by knpenny » Sun May 20, 2018 10:02 pm
cheers fellas, thats really appreciated. Will get that sorted in the next couple o day, might even change the leisure battery while i'm at it :D :idea: see what the funds say to it :roll:
