Alternator
KMH
Alternator
Post by KMH » Fri Apr 28, 2017 7:08 pm
My poorly Bongo is in need of a new alternator (it has been tested so I'm certain this is the problem!) and is currently parked on a friend's driveway in Cambridge. Does anyone know a mobile mechanic who could fit a new alternator onsite? Or would it need to go to a garage? It's a slightly long and complicated story and I'm trying to find the easiest solution! Thank you, in hopeful anticipation!
Re: Alternator
Post by Bob » Fri Apr 28, 2017 7:23 pm
This is a fairly simple diy job, and someone very recently sourced one and posted details on here.
I've a good idea there's a Youtube vid, too. 8)
Re: Alternator
Post by mikeonb4c » Fri Apr 28, 2017 7:29 pm
Could the battery be charged so it could get to a nearby garage? I drove my diesel all the way from stourport to Manchester with a u/s alternator.
KMH
Re: Alternator
Post by KMH » Fri Apr 28, 2017 7:47 pm
Thanks both. I don't live in Cambridge and the complicated circumstances mean that getting the Bongo to a garage, though possible as you suggest, is tricky. Hence the hope for a trustworthy mobile mechanic.
Re: Alternator
Post by Bob » Fri Apr 28, 2017 8:15 pm
Not a recomendation, I know nothing about them, but this came up.
https://www.clickmechanic.com/locations ... Anif8P8HAQ
You could get the correct alternator delivered to the houuse then arrange to have it fitted.
KMH
Re: Alternator
Post by KMH » Fri Apr 28, 2017 10:06 pm
Thanks, Bob, I found them too and might give them a ring. Ordering one is. great idea, too. In other circumstances I'd love to have a go at DIY with the friend whose drive it is on, but sadly illness means that can't happen this time.
Re: Alternator
Post by Bob » Fri Apr 28, 2017 10:15 pm
These guys have been recommended on here:
http://www.startermotor-alternator-stor ... 2681-p.asp
Or, of course, Bongo Spares for second hand. :wink:
Re: Alternator
Post by Northern Bongolow » Sat Apr 29, 2017 3:33 am
make sure its rated at 90 amps, theres several out there that are pretending to be that are actually lower, 80 amps usually last a year then fail.
theres seval good local bongo owners that may see this, come on lads. :wink:
Gasy
Re: Alternator
Post by Gasy » Sat Apr 29, 2017 3:39 pm
Hi kmh
Just an idea but get the alternator and see if the AA / RAC will fit it
As a breakdown call out :D
al & chris
Re: Alternator
Post by al & chris » Sat Apr 29, 2017 9:41 pm
Our alternator went in Scotland a few years ago when on hols. AA sourced one from a breakers fitted it and it's still fine now.
