Switch Blanks
MalcW
Switch Blanks
Post by MalcW » Fri Feb 24, 2017 4:13 pm
Hi, I've bought a Haydn alarm which I'll fit ASAP. I'd like to put the LED in one of the rocker switch blanks - probably the one to the right of the front fog lamps switch. But, how do you remove the blank? It moves slightly and probably just unclips but I didn't want to force it and break something. Thanks.
Re: Switch Blanks
Post by mikeonb4c » Fri Feb 24, 2017 4:24 pm
MalcW wrote:Hi, I've bought a Haydn alarm which I'll fit ASAP. I'd like to put the LED in one of the rocker switch blanks - probably the one to the right of the front fog lamps switch. But, how do you remove the blank? It moves slightly and probably just unclips but I didn't want to force it and break something. Thanks.
I've removed several of these but it was years ago and i've forgotten how #-o. Maybe see if you can get your hand behind the dashboard to pinch them and push them. Other than that i suspect i might have tried small watchmakers screwdrivers used as levers on top or bottom edge to both pinch and prise them from their slot. These might leave a small witness gouge, but substantially out of sight.
But wait and see what others say.
Re: Switch Blanks
Post by g8dhe » Fri Feb 24, 2017 6:07 pm
Usually just a few barbs that catch on the frame work holding it in place.
the1andonly
Re: Switch Blanks
Post by the1andonly » Fri Feb 24, 2017 11:01 pm
A really adventurous place to put the led is in the right hand dial next to the temp gauge. need to remove main display and a bit of drilling. in mine, as observed from rear there were obvious places. sorry but unable to source pictures.
Re: Switch Blanks
Post by mikeonb4c » Fri Feb 24, 2017 11:21 pm
the1andonly wrote:A really adventurous place to put the led is in the right hand dial next to the temp gauge. need to remove main display and a bit of drilling. in mine, as observed from rear there were obvious places. sorry but unable to source pictures.
That's where i put mine and v neat it is too. Not especially difficult but sharp drill bits and care needed drilling through the panel so as not to crack the thin brittle plastic.
haydn callow
Re: Switch Blanks
Post by haydn callow » Sun Feb 26, 2017 10:14 am
I've removed hundreds of switch blanks whilst fitting the alarm LEDs... I just get a medium screwdriver and lever at the of the switch top till it 'pops' out then do the same at the bottom. I guess 50 % of the time the switch blank gets damaged but never badly enough that they carnt be used. It's the small lugs at the back that break and there are always enough left to refit the blank and once refitted no one will ever know.
Top Tip :- just go for it.
http://www.coolantalarm.co.uk
Also BMW Clocks
