Cigarette Lighter Replacement
The fusible link in my dashboard socket has blown so I have pulled it out initially intending to replace the wire with some fuse wire. I then got to thinking why not just replace the whole thing with a native USB socket as that is all we ever plug in there. Has anyone else done this and can they recommend a good replacement? I have seen these on eBay which look like they might do the job?
Alan
Alan
Re: Cigarette Lighter Replacement
I did that on the VW. Worked fine for a good while but then failed. It meant changing the whole thing,a bit of a mission on the VW.
So I replaced it with a good quality ciggy lighter and used a USB chager adaptor from then on.
Not so restrictive.
Not so restrictive.
- Jimbobvfr400
If you have a spare switch blank free then these fit with a tiny little bit of filing.
http://www.ebay.co.uk/itm/12V-24V-Dual- ... SwnHZYfyRN
Jamie, Caroline and the kids.
2002 V6 Aero AFT
2002 V6 Aero AFT
Thanks guys. Hadn't seen the rectangular one, looks interesting. Think I'll try a replacement for the existing socket initially and repair the faulty one and stick it in the glove box for emergencies
Well spotted, just bought four!Jimbobvfr400 wrote:If you have a spare switch blank free then these fit with a tiny little bit of filing.
- the1andonly
- Tribal Elder
Only 7 left!
one should be enough for me
a few little jobs appearing end march/ april
- Jimbobvfr400
It wasn't entirely my idea but they are a pretty neat solution.
Mine had a blue LED next to both ports which was a bit bright and unnecessary, the casing pried apart quite easily and I just snipped the LEDs off.
2002 V6 Aero AFT
2002 V6 Aero AFT
- the1andonly
- Tribal Elder
Thanks for the info about blue LEDs. SWIMBO complains like "expletive deleative" about a blue LED "thing" that i've got in the Bongo.
but probably wont complain (too much) when we can charge 2 phones and power my "thing". and an AA battery charger all at same time,
Whoopee!
Whoopee!
Black electrical tape.
- the1andonly
- Tribal Elder
I need to see my " thing" is working
no inuendo
please bob
i'm 3 old for that
no inuendo
please bob
i'm 3 old for that
FOUR! You setting up the Wasp as a USB Charging Cafe for campers or something?Bongolia wrote:Well spotted, just bought four!Jimbobvfr400 wrote:If you have a spare switch blank free then these fit with a tiny little bit of filing.
mikeonb4c wrote:FOUR! You setting up the Wasp as a USB Charging Cafe for campers or something?Bongolia wrote:Well spotted, just bought four!Jimbobvfr400 wrote:If you have a spare switch blank free then these fit with a tiny little bit of filing.
- Jimbobvfr400
Pfft, amateurs, I've only got 14 USB Sockets in my van, with at least 2 more to be added in the AFT when I get round to it.mikeonb4c wrote: FOUR! You setting up the Wasp as a USB Charging Cafe for campers or something?![]()
2002 V6 Aero AFT
2002 V6 Aero AFT
Madness i tell ee
