has anyone an idea of the size socket I will need for the large nut my 22mm is to small
brake pipes
				davepickering
 - Bongonaut
Re: brake pipes
another good link Bob just looked on ebay nut splitter £5.99 prob only use once
						Re: brake pipes
davepickering wrote:good link,, http://www.ebay.co.uk/itm/SEALEY-VS0342 ... 2008135223?..........shame the nut is 10mm..
and checked to day and it has been put in cross threadedso hay ho out comes the hacksaw done in no time only problem now is the tw**t that worked on it before has also rounded off one of the bolts holding the back plate on
and also I haven't got the size to get a socket for the large nut either yet
...will have to purchase a nut splitter (for the small nut) this job is growing daily
http://www.ebay.co.uk/itm/Sealey-Flare- ... SwFnFV--Y6
				davepickering
 - Bongonaut
Re: brake pipes
Thanks Rita for the link
						Re: brake pipes
I've a set of them on bobs link ^^^^
Bloody good
Had some locking wheel nuts of as quick as with a key for them
Whack them on with a lump hammer
									Bloody good
						Re: brake pipes
We did the same with my neighbour's Merc.
						Re: brake pipes
If the pipe is being replaced just cut it off at the nut then use a 6 sided socket to remove the fitting
Loads of wd40 the night before is a good idea, in the unlikely event the nut rounds off use these.
http://www.irwin.com/tools/screw-bolt-e ... ansion-set
I have just replaced mine on a 20 year old Discovery the local factors charges me about £10 for three long pipes with fittings, it works out cheaper as I didn't have to buy a role of pipe that would sit in the garage for years
				davepickering
 - Bongonaut
Re: brake pipes
thanks  Winchman will keep that in mind  but still trying to find the size of the  large nut at the top of the back plate and still sorting getting off the rounded over 14mm nut off
once that's sorted and new bearing on will start to rebuild brakes
				davepickering
 - Bongonaut
Re: brake pipes
just checked out your link winchman I think I will be getting that for both nuts brilliant post thanks
was getting a bit down hearted
  but feel better now
				davepickering
 - Bongonaut
Re: brake pipes
large nut I think is around 23mm or 24mm so will prob go buy them today
						Re: brake pipes
Loads od wd40 and it should come off Make sure the extractor fits before you buy it!.Local garage may lend you one?davepickering wrote:just checked out your link winchman I think I will be getting that for both nuts brilliant post thanks
was getting a bit down heartedbut feel better now
Make sure they are this shape in side
https://www.amazon.co.uk/Irwin-Bolt-Gri ... B000QW6K8I
Other types I have tried didn't work.
Recently tied some of these on a seized rounded off calliper bolt, Tried my set like in the earlier post and it came out first time.
http://www.ebay.co.uk/itm/Draper-Expert ... SwVL1WB6ZQ
Show us a photo of the issue as there may be an easier way
Re: brake pipes
Pity you are so far away I could lend you onedavepickering wrote:large nut I think is around 23mm or 24mm so will prob go buy them today
				davepickering
 - Bongonaut
Re: brake pipes
do you think I should go for the dearer set or are these the same
IRWIN 5 Piece BASE Damaged Bolt Grip Nut Remover Set 10-16mm + Case,10504634 on ebay
Re: brake pipes
http://www.ebay.co.uk/itm/IRWIN-5-Piece ... SwWntXMmcDdavepickering wrote:do you think I should go for the dearer set or are these the same
This is only a half set but at £14.80 its cheaper than screw fix
The yellow cardboard in the box lifts out and you can buy the next 5 bigger sizes to fit in the case.
http://www.ebay.co.uk/itm/IRWIN-10-Pce- ... Sw7ehXRGri
I have the small set at work and you always need the one size you don't have, set I have at home is a 10 piece Crafstman one bought years ago in Florida for about £20
If the cheap set has the correct size in it its worth it as it will get it out, what can you buy these days for £15?
				davepickering
 - Bongonaut
Re: brake pipes
keeps telling me photo file to big
						Re: brake pipes
Have to use photo shrink to make it smaller or host on photo bucket and post  link
