Alernator Identity
Alernator Identity
1996 cold region 2 x battery, 2.5 TD, 4 x 4 - stumped as no label on alternator - overcharging suspected - has any bongalier got a note of what alternator is LIKELY to be fitted to my model.
Re: Alernator Identity
theres only one alternator for the diesel. but there are 2 different starter motors , one winter pack and one standard.
ian at bongo fury is doing an exchange on alternators, give fury a ring.
http://bongoland.co.uk/product/alternator-diesel/
mine is Hitachi LR190731B, and reasonably sure it is original.
Chris with BertieB
make sure you buy the correctly rated one, 90 amp is the gen mazda, some of the cheaper ones advertised on the net for bongo;s are only 80 amps, they usually last 1 year and 1 day on a bongo, just out of warranty.
Here you go, Brand New , green band,90amps.
Good Luck...
http://www.ebay.co.uk/itm/282233557809? ... EBIDX%3AIT
Good Luck...
Out of interest, how do we know which of the above brands (Hitachi, Elite) is the one fitted as standard by Mazda. I find the alternator market bewildering!
this cheaper recon doesnt deserve the catchy trade name sticker of aapoldham
. andys auto parts oldham.
http://www.ebay.co.uk/itm/MAZDA-BONGO-I ... 2233557809
Could it even be both? I've known manufacturers to fit the same component from different sources. Mine looks very original and is Hitachi.mikeonb4c wrote:Out of interest, how do we know which of the above brands (Hitachi, Elite) is the one fitted as standard by Mazda. I find the alternator market bewildering!
Chris with BertieB
looks like you have a pipe missing.
thats the standard and only gen mazda one ive seen on a bongo, the others are usually black banded aftermarket.
specially removed for clarity. It'll still run fine, won't itNorthern Bongolow wrote:looks like you have a pipe missing.thats the standard and only gen mazda one ive seen on a bongo, the others are usually black banded aftermarket.
Chris with BertieB
air cooled bongo, now theres a thought, cut out a few of the known problems in one job.
- Junior Bongonaut
Hello try this one buddy
https://www.startermotor-alternator-sto ... %20(A1633)
Seems to be the common alternator for bongos
I'm looking to find what alternator brushes I need to refurb mine
