Back door and catch
Frankie
Back door and catch
Post by Frankie » Mon Sep 05, 2016 9:46 am
I am looking at a bongo to buy and the seller has warned me to be careful with the back door. 'dont slam' etc as they've had problems with the catch. Is this a common problem, has anyone heard of it? Can it be fixed. Seems pretty serious to me, back door opening while driving etc!
Re: Back door and catch
Post by g8dhe » Mon Sep 05, 2016 9:58 am
Not heard of any problems before ? The TinTop doesn't have an internal handle I believe as standard but people have retro-fitted them as the muntings points etc are all there.
Post by Bob » Mon Sep 05, 2016 1:54 pm
I've never heard of that either.
Wonder if he's trying to shift a motor with problems. :?
wonkanoby
Post by wonkanoby » Mon Sep 05, 2016 3:21 pm
you can adjust the bit latch catches on
Post by mikeonb4c » Mon Sep 05, 2016 5:05 pm
I wonder if he's referring to the electric soft-close on the sliding door - i've heard they don't like being slammed though not heard any direct experience of it. When mechanism does play up (usually after battery disconnection) its usually proved to be inexpensive (if a bit fiddly) to fix.
Frankie
Post by Frankie » Mon Sep 05, 2016 8:40 pm
No it was definitely the back/boot door
Post by mikeonb4c » Mon Sep 05, 2016 11:30 pm
Frankie wrote:No it was definitely the back/boot door
Sounds like someone's talking bollox then ;-)
Gasy
Post by Gasy » Tue Sep 06, 2016 6:59 am
If it is a dodgy catch on the back door
That's not a serious problem
Quick cheap repair / replace
These are 20 year old vehicles
They do get small problems every now and then
teenmal
Post by teenmal » Tue Sep 06, 2016 10:02 am
It might be worthwhile removing the trim and checking out the rear floor section for corrosion/rust, also the inner bottom of the tailgate.
It might also be worthwhile checking that the spare wheel mechanism is not overtightened as this can upset the catch/door adjustment.
Frankie
Post by Frankie » Sat Sep 10, 2016 10:51 am
Interesting . It is log converted, I wonder if putting the tank in the spare wheel cavity affected the door mechanism?
Frankie
Log = lpg blooming spell check!
teenmal
Post by teenmal » Sat Sep 10, 2016 4:13 pm
Frankie wrote:Log = lpg blooming spell check!
Nothing wrong with a log burner.
:D
