please, please, please tell me i just need to put air in the tyres or fill up the washer bottle the holiday has already cleaned me out!
Any advice would greatly appreciated
Sounds like your gearbox is going into default mode which signifies a fault. Does the hold light flash when this is happening?ned wrote: whilst accelorating up a hill at about 75 - ish, it suddenly "kicked down" and started screaming at me at nearly 5000 revs but wouldn't stop, the only way i could get back into top gear was to take foot off accelerator. All the way home this kept happening only when over 60 mph usually on hills however would not come out of "kick down" even when over other side of hill, only way was to take off accelorator. Had no probs though when on slower roads went through lower gears absolutely fine...
