Front Fog Lights
morangopat
- Junior Bongonaut
Front Fog Lights
Has anyone any advice regards fitting front fog/road lights in the two lower bumper slots.
E.g. Best lights and where to get them from; any technical fitting issues.
Re: Front Fog Lights
what year and engine have you mate, is it an aero or standard.
I believe I've read on here some years back that, where people have been unable to source originals (which used in any case to often go for silly prices) they have managed to use these:
http://www.ebay.co.uk/itm/Ring-Roadrunn ... SwY45UThCE
You need some DIY skills to make up holding brackets but at that price its not a disaster if one breaks after a stone strike etc. If anyone reading this has experience of fitting them, maybe they could offer a comment?
Stick some mirror foil onto the press out panels and they will light up when someone comes the other way with everything blazing.
No wiring or brackets needed, minimal cost and they look really smart in daylight too.
Frank
Frank
They flew, I took up naturism
Ooh you are awful Frank. But I like that ideaDiplomat wrote:Stick some mirror foil onto the press out panels and they will light up when someone comes the other way with everything blazing.
Frank
I've had the idea for quite a while.
Just can't remember where I put the mirror stuff.
Frank
Frank
I fitted these to my previous bongo, good quality. I did some just make some simple brackets to hold them in place using the original screw holes. Quite easy. They were tough and worked well and fitted the holes good.mikeonb4c wrote:I believe I've read on here some years back that, where people have been unable to source originals (which used in any case to often go for silly prices) they have managed to use these:
There's a fact sheet about fitting these, including the wiring, in the member's area of the main website.
Excellent + excellent to hear of Stuc's experience. So there you have it - give the Mazda originals a miss, go for the Rings, and spend just a bit of the saving on joining Bongo FuryIan wrote:There's a fact sheet about fitting these, including the wiring, in the member's area of the main website.
morangopat
- Junior Bongonaut
Thanks to all for the replys
Mazda Bongo Model KD-SGL3 Diesel
First Reg. 01 06 1997
First reg UK 01 03 2007
Makers Serial No SGL3-107076
I would really like the road lights. I am a member. Will search out fact sheets. Rings?
Thanks to all
Thanks to all
morangopat
- Junior Bongonaut
Thanks Supreme Being found your bit about RINGS, cheers
