Fassi
Post
by Fassi » Sun Aug 16, 2015 1:18 pm
Me again.
So I've pulled in at a car park and I noticed dripping from underneath the bonnet onto the ground. It looks like it comes from two places. The pipe top left of photo which must be the front aircon drain. But also the flange looking thing where the two pipes, one thicker than the other join. What is this part and any idea what I should do? Thanks again.
1995 2.5 TD
Fassi
Post
by Fassi » Sun Aug 16, 2015 1:45 pm
Seems they are aircon pipes too. Leak might explain why the aircon was empty of refrigerant when I got it.
1995 2.5 TD
helen&tony
Post
by helen&tony » Sun Aug 16, 2015 2:45 pm
Do you mean the 2 pipes clamped together?
Fassi
Post
by Fassi » Sun Aug 16, 2015 3:30 pm
helen&tony wrote:Hi
Yes those two. Just drove for an hour without the aircon on and there was no leaks.
1995 2.5 TD
Simon Jones
Post
by Simon Jones » Sun Aug 16, 2015 3:36 pm
Those pipes will get covered in condensation and possibly even some ice when the A/C is on so it is normal for them to be wet after use. Refrigerant generally has a bright green dye so should be easy to detect if that is leaking.
Fassi
Post
by Fassi » Sun Aug 16, 2015 3:39 pm
Simon Jones wrote:Those pipes will get covered in condensation and possibly even some ice when the A/C is on so it is normal for them to be wet after use. Refrigerant generally has a bright green dye so should be easy to detect if that is leaking.
Great mate. Thanks very much. I'm just so paranoid at the moment about every little thing with the bongo.
1995 2.5 TD
