2WD drive shaft.
Rapidair65
2WD drive shaft.
Post by Rapidair65 » Fri Jun 19, 2015 12:59 pm
Is is possible to lubricate the universal joints on the 2WD drive shaft? Also, if the joints are shot, is is possible to replace them or do you have to replace the complete shaft?
1998 green and silver V6 called 'Blossom'
2004 white 2 litre tin top called Buzz.
teenmal
Re: 2WD drive shaft.
Post by teenmal » Fri Jun 19, 2015 1:09 pm
It is possible to grease the UJ (Hardy Spicer) if it has Grease Nipples Fitted, and yes you can fit replacement UJ to the prop shaft .
Simon Jones
Post by Simon Jones » Fri Jun 19, 2015 2:09 pm
Current discussion on driveshaft U/J's: http://www.igmaynard.co.uk/bongo/forum/ ... 4&p=657205
Post by Northern Bongolow » Sat Jun 20, 2015 1:23 am
looking at the other car forums discussions replacement of the bongo (staked type) not circlip type seems really hit and miss as they are hard to do well as the balance is very important, there are companies out there that will do a great replacement with grease nipple fitted. the standard bongo joint is not fitted with a grease nipple.
http://www.parkinsons.co.uk/workshops_o ... hafts.aspx
