won't start
lancyman
won't start
Post by lancyman » Sat May 16, 2015 10:50 am
Hi all
Van would not start this morning. Power in the battery but
it's dead and won't turn over. Dead as dead thing. Any idea
Thanks.
silage
Re: won't start
Post by silage » Sat May 16, 2015 10:55 am
May not be enough currant to turn starter?
" The harder you work, the richer you die"
97 4WD 2.5 TD
G0JZW
Re: won't start
Post by Bob » Sat May 16, 2015 10:56 am
Stareter motor/solanoid?
Earth somewhere?
roosmith
Re: won't start
Post by roosmith » Sat May 16, 2015 11:12 am
Alarm/immobiliser?
lancyman
Re: won't start
Post by lancyman » Sat May 16, 2015 2:19 pm
No alarm or mobilise fitted. I turn the key and nothing. But lights will come on.
just seems totally dead.
Re: won't start
Post by Northern Bongolow » Sat May 16, 2015 2:23 pm
have you got a multi meter?
lancyman
Re: won't start
Post by lancyman » Sat May 16, 2015 2:47 pm
No not at minute.
Simon Jones
Re: won't start
Post by Simon Jones » Sat May 16, 2015 3:45 pm
Do all the dash lights go dim when you try to start it? If so, it would indicate low battery voltage.
lancyman
Re: won't start
Post by lancyman » Sat May 16, 2015 3:51 pm
No nothing comes on at all Simon.
Simon Jones
Re: won't start
Post by Simon Jones » Sat May 16, 2015 3:59 pm
Check the big fuses under the bonnet especially the green 'main' fuse.
Re: won't start
Post by g8dhe » Sat May 16, 2015 4:29 pm
lancyman wrote: But lights will come on.
Which lights come on then ?
mikeWalsall
Re: won't start
Post by mikeWalsall » Sat May 16, 2015 5:06 pm
If the battery and connections are OK .. Maybe 'iffy' starter contacts .. give the starter motor a tap with an hammer .. may free them ..
lancyman
Re: won't start
Post by lancyman » Sat May 16, 2015 5:14 pm
Side lights came on OK. I'll check big fuses.
cookan
Re: won't start
Post by cookan » Sat May 16, 2015 6:15 pm
the tell tale sign that it's starter solenoid contacts would be if it's ever just made a 'click' but not started first time...but then the next time you turn the key it starts fine and you think nothing of it...
if that's something you recognise, give the starter a tap as mentioned above to get things moved around a little inside..
Ant.
1995 M reg 2WD AFT in green/grey (and an Oakley Thermonuclear Protection decal for some reason!)
lancyman
Re: won't start
Post by lancyman » Sat May 16, 2015 6:46 pm
The 100 amp main fuse has blow. Don't think that's it.
where is the starter motor to tap?
