Key won't alway come out!
silage
Post by silage » Sun Apr 05, 2015 3:09 pm
Ok, me again, Barri has taken a liking to holding on to the key at the end of a journey. I put brake on and put gearbox in to Park, it normally means another sort trip down the road to reset something before the key will come out!!!!!
It not all the time just when its going to be bloody annoying and cause friction between Mrs silage and me :lol: :D
any ideas O wise one's :D
" The harder you work, the richer you die"
97 4WD 2.5 TD
G0JZW
scanner
Re: Key won't alway come out!
Post by scanner » Sun Apr 05, 2015 4:21 pm
Sounds like the gear selector interlock is playing up, just try putting it in and out of park a few times to see if that helps.
Post by g8dhe » Sun Apr 05, 2015 5:30 pm
Check and adjust the cable 46-300 in the diagram below;
silage
Post by silage » Sun Apr 05, 2015 7:06 pm
Thanks, any info on adjusting cable? plus location etc.
97 4WD 2.5 TD
G0JZW
Post by g8dhe » Sun Apr 05, 2015 7:11 pm
Well the location is the front of the gear selector, take off the central console etc.
Also see here http://www.igmaynard.co.uk/bongo/forum/ ... 34#p587734
teenmal
Post by teenmal » Sun Apr 05, 2015 7:18 pm
Hi silage, did you get your new ignition key?.
silage
Post by silage » Sun Apr 05, 2015 9:09 pm
yes new key for wife to use, she don't drive,only me mad :lol: , but go her one to be able to have access if im not around.
97 4WD 2.5 TD
G0JZW
scanner
Post by scanner » Sun Apr 05, 2015 9:26 pm
silage wrote:yes new key for wife to use, she don't drive,only me mad :lol: , but go her one to be able to have access if im not around.
Tip...
Use the new one yourself for at least a while to wear it in a bit.
teenmal
Post by teenmal » Sun Apr 05, 2015 9:55 pm
Tip...
Sound advice.....
:lol: :lol: :lol: :lol:
silage
Post by silage » Tue Apr 07, 2015 7:37 am
yes will try that, all so put switch cleaner in to key switch and seems ok at mo, but good to have another option with cable if problem returns. :D
97 4WD 2.5 TD
G0JZW
Simon Jones
Post by Simon Jones » Tue Apr 07, 2015 7:54 am
Graphite dust from a pencil is a good trick to lubricate a sticky key. Be careful about using switch cleaner as it will wash out the lubrication already in the lock.
silage
Post by silage » Tue Apr 07, 2015 12:23 pm
Good point :oops:
97 4WD 2.5 TD
G0JZW
