Coolant alarm screw
rita
Re: Coolant alarm screw
Post by rita » Sat Jan 31, 2015 5:29 pm
14v at the ring terminal sound a weeee bit OTT .
haydn callow
Post by haydn callow » Sat Jan 31, 2015 7:32 pm
If you are getting 14 volts at the screw ( volt meter between screw and earth ) you have a massive problem.
To measure the amps you need to remove the ring terminal from the sensor screw and put the ammeter between the ring terminal and the sensor screw head.
That voltage though if you are doing it right is massive and I suggest you remove the alarm and return it to us to check out........you cannot leave things as they are. Whatever is going on is not good and needs sorting
http://www.coolantalarm.co.uk
Also BMW Clocks
spud350
Post by spud350 » Sat Jan 31, 2015 11:21 pm
I'll double check tomorrow.
spud350
Post by spud350 » Fri Feb 06, 2015 3:54 pm
So this is the voltage. I couldn't get a current reading, it must have been too small?
haydn callow
Post by haydn callow » Fri Feb 06, 2015 4:46 pm
I don't know what's going on ....must be wired wrong but for peace of mind send it back to be checked out.....
Also BMW Clocks
Post by g8dhe » Fri Feb 06, 2015 11:05 pm
Check the earth connection to the main unit, maybe that has broken and your just seeing the supply voltage via the unit.
spud350
Post by spud350 » Sun Feb 08, 2015 8:29 pm
To late, I've sent it back for Haydn to see if I've fried anything inside. #-o
haydn callow
Post by haydn callow » Tue Feb 10, 2015 12:42 pm
Spud350..... Alarm checks out perfectly......it's on its way back......suggest you follow the installation instructions and all should be well.....if it still misbehaves, you have a problem within your Bongo....
If you want to re return it we will buy back.
Also BMW Clocks
rita
Post by rita » Wed Feb 11, 2015 5:54 pm
Spud, it would probably be worthwhile having you cooling system components and coolant checked/examined, if the problem has caused the screws to corrode it might have caused more hidden damage and contamination to the system .
Good Luck.
haydn callow
Post by haydn callow » Wed Feb 11, 2015 6:07 pm
That wouldn't explain the 14 volts which if correct is probably eating away at all sorts of components including the radiator and water pump.
Also BMW Clocks
spud350
Post by spud350 » Sat Feb 28, 2015 4:29 pm
So I've got hold of a piggyback fuse connector which I didn't know existed but anyway after much tinkering this is the result ...
So with any luck the job is a good one. Thanks for all the replies and to Haydn who checked out the alarm for free and sent back a new set of wires and connectors with it.
Spud.
helen&tony
Post by helen&tony » Sat Feb 28, 2015 5:07 pm
Excellent...and good service from Haydn...you won't get that elsewhere! =D> =D> =D> =D>
haydn callow
Post by haydn callow » Sat Feb 28, 2015 6:27 pm
That's still a bit high, try removing the sensor screw, wire brush and refit....then report back with a reading.
Also BMW Clocks
spud350
Post by spud350 » Sun Mar 01, 2015 12:54 pm
With it all disconnected as before and the meter on the ring terminal and earth it's reading 12.6v. I can't see it getting any closer to 12v myself. Is this Ok as I'm getting the power for it from the dash fuse. [-o<
haydn callow
Post by haydn callow » Sun Mar 01, 2015 4:40 pm
You've now lost me.......you have a photo above reading 2.07 volts.......now you are saying 12.4..
Do not remove the ring terminal from the screw......do it in situ ....you should get 1.8 if all is 100%
Also BMW Clocks
