Coolant alarm screw
spud350
Coolant alarm screw
Post by spud350 » Wed Jan 21, 2015 7:24 pm
A few times over the last couple of years I've had to change the screw that's screwed into the expansion tank. I know it's going as the alarm takes longer and longer to go off after start up. It's a pain in the a**e as I have to wrestle the leisure battery out which is flippin heavy and a tight fit.
It does surprise me however that in such a short time the screw is totally corroded away (and they're stainless). The ring connector also has to be changed as that's virtually gone as well.
Does anyone else get this problem or do I have particularly corrosive coolant? :?
Gasy
Re: Coolant alarm screw
Post by Gasy » Wed Jan 21, 2015 7:35 pm
Are you replacing with stainless screws
Never heard of them being corroded away ( but I'm no expert )
They should get coated with a protective layer from the coolant and require a good clean once in a while
What alarm do you have
Post by Northern Bongolow » Wed Jan 21, 2015 7:48 pm
what coolant have you in the bongo mate, ive never heard of this happening.
my wife and i have a bongo each both have coolant alarms, neither have been even cleaned in all that time, my mrs is on her second batch of 5 year coolant, so thats 2 lots of red coolant that lays down a dissimilar metal isolation layer on everything.
i use carplan premium red or comma 5 year red.
Post by Simon Jones » Wed Jan 21, 2015 7:53 pm
Is this a Haydn alarm or one of the others on the market? They work by passing a very small current through the coolant which in itself should not cause a problem. Stainless steel screws will not rust away but they can build up a coating.
You may have a bigger problem with electrolysis within the system which could be significant if unattended to. Are you using a decent brand of coolant and has it been changed within the last two years?
spud350
Post by spud350 » Wed Jan 21, 2015 9:35 pm
Dunno what coolant is in it. It's either the same stuff that was in from Japan or something that the garage I bought it off put in.
The reason I haven't changed is the obvious I don't want issues with cooling system after unnecessary messing about. I just wondered if anyone else has this corrosion issue. The screws aren't attracted to magnets so I assume they're stainless.
Maybe the current going through mine is to much for some reason?
Edit: just bought some pH strips off ebay. This will hopefully prove the corrosive coolant theory or not. [-o<
Post by Simon Jones » Wed Jan 21, 2015 10:04 pm
Conventional coolant should be replaced every two years as that is the typical life of the anti-corrosion properties. I understand the 'ain't broke don't fix' approach but with service items with a limited lifespan it's more of a case of 'prevention is better than cure'.
Post by haydn callow » Wed Jan 21, 2015 10:06 pm
Measure the voltage between the screw head and earth with engine running.......
You have A problem not directly related to the alarm.
This. Is a new one!!
Also if you can get a reading you should be less than 50 micro amps at the screw
Post by haydn callow » Thu Jan 22, 2015 12:46 pm
Been in touch with our research division in Oz......?Baffled......where did you get your replacement screws from ???? Are they A4 stainless???
If your eating quality screws I dred to think what else is getting scoffed......
Suggest you do a full coolant flush/ change and phone the webshop for a new screw.....measure the volts/amps and start again......
Post by haydn callow » Thu Jan 22, 2015 12:49 pm
I notice you joined in Feb 2010.....so your coolant is more than 5 years old"......no a good idea....what colour is it??
Post by rita » Thu Jan 22, 2015 1:12 pm
What was the cure the last time......
http://igmaynard.co.uk/bongo/forum/view ... rm#p556446
Post by Simon Jones » Thu Jan 22, 2015 1:38 pm
So alarm appears to be running off the LB and the result sounds like electrolytic corrosion which might indicate a poor earth between LB & engine/chassis. If it were me, I'd put the LCA on to an ignition-switched supply inline with the previous guidance from Haydn.
Post by haydn callow » Thu Jan 22, 2015 6:05 pm
Just read the previous topic of yours highlighted by Rita above.......in that you mention how clean the screw was but you had it wired wrong.....
Suggest you get back to basics and fit the alarm as pier instructions after sorting the coolant.
spud350
Post by spud350 » Thu Jan 22, 2015 10:04 pm
Right I'll try to answer the questions
haydn callow wrote:Measure the voltage between the screw head and earth with engine running.......
Right I'll try that this weekend, but i'm not sure my meter is that accurate, will take a look.
haydn callow wrote:Been in touch with our research division in Oz......?Baffled......where did you get your replacement screws from ???? Are they A4 stainless???
The screws are off ebay, not sure of the material but I've never come across anything other than A4 in normal circulation. That doesn't mean they're not that though. Will get another.
haydn callow wrote:I notice you joined in Feb 2010.....so your coolant is more than 5 years old"......no a good idea....what colour is it??
Erm, yes. :-" Blue or green, definitely not red.
rita wrote:What was the cure the last time......
Good question I can't remember. I think I must have just changed the screw or cleaned the contact between it and the ring terminal or something. Nothing out of the ordinary springs to mind.
Simon Jones wrote:So alarm appears to be running off the LB and the result sounds like electrolytic corrosion which might indicate a poor earth between LB & engine/chassis. If it were me, I'd put the LCA on to an ignition-switched supply inline with the previous guidance from Haydn.
If I can brave the cold I'll check the wiring again. I don't recall how it all ended up being done. People say I have a short memory. I've no idea what they mean. :oops:
haydn callow wrote:Just read the previous topic of yours highlighted by Rita above.......in that you mention how clean the screw was but you had it wired wrong.....
Righto.
Post by haydn callow » Fri Jan 23, 2015 9:57 am
There are several grades of stainless...
A2. Is the lowest you might get away with.
A4 is what we supply and is good.
Buying a non standard screw is asking for trouble, the diameter,thread, pitch, length and quality are all important.
Get a replacement from us....( they are free )
Afraid it would seem your problems are self inflicted.
spud350
Post by spud350 » Sat Jan 31, 2015 2:58 pm
Edit: OK something odd here, I'm getting 14v at the ring terminal but also 1.4mA which is massive (relatively speaking) if that 50 microamps is correct. However am I measuring it correctly by putting my meter between the terminal and negative?
