They seem to be a relatively new and very ingenious method for taking a feed from an existing fuse box. However, you could use them in reverse to feed power from the LB to run the blinds, radio etc. The unit replaces the original fuse and then it has room for two fuses (one for the original item and one for the new feed).
I got them from this seller for £10 (of which £2.27 was postage) which is fantastic value. For that you get 5 mini-blade adapters and 5 standard size, plus 5a fuses for each.
http://www.ebay.co.uk/sch/vacie2832/m.h ... 7675.l2562
