Post
by mikeonb4c » Mon Dec 22, 2014 1:51 pm
fieldy1978 wrote:Ok cool, going to check timing 100 percent using the bellhousing method rather than mirrors. Prime the system as much as possible and then use the carb cleaner to try get her started.
It's beginning to sound like something out of Flight of the Phoenix!
Good luck Hoskins
fieldy1978
- Bongonaut
Post
by fieldy1978 » Mon Dec 22, 2014 3:02 pm
Ok so the mirror method is really really crap! The crank was about 10 degrees out.set crank to 0 degrees(correct??) Then removed belt and spun can so marks line up. Belt back on, turned over and re checked.all in time. Carb cleaner direct into manifold and nothing. Cracked off injectors one at a time and a the engine turns a low pressure spurt comes out. Should this come out at a horrendous pace or give just spurting out on crank over. Waiting for my friend to come over who borrowed myhd jump leads to connect to my truck for some good cranking action.
fieldy1978
- Bongonaut
Post
by fieldy1978 » Mon Dec 22, 2014 3:04 pm
If still no joy worth looking at the valves? I have a petrol compression test but nota diesel. Cranking over by hand it certainly doesn't feel low pressure!
nth
Post
by nth » Mon Dec 22, 2014 6:13 pm
If it's not even thinking about firing when you spray carb cleaner directly into the inlet manifold thats not good, would suggest no compression ?
95 2.5d 4WD AFT
fieldy1978
- Bongonaut
Post
by fieldy1978 » Mon Dec 22, 2014 6:21 pm
Ok jump leads on and spray she is firing.going to refit the elbow on inlet and try spraying easy start into the intake pipe and mess about with the pump to try and get it running healthyish.just need to see if the knocking had gone or not.
fieldy1978
- Bongonaut
Post
by fieldy1978 » Mon Dec 22, 2014 11:14 pm
Lol yeah that's all i had on the shelf. Halfords for me in the morning! !
fieldy1978
- Bongonaut
Post
by fieldy1978 » Tue Dec 23, 2014 5:37 pm
Still rattling. Engine running but same rattle.guy who owns bongo spares told me about the balance bar in the engine so going to lift the engine tomorrow.is it a crap job?
