A Pela pump is a handy thing for sucking most of the oil out first, because the oil level is normally above the top of the sump so as soon as you loosen the bolts....
Also you need to be careful with the gasket unless you buy a new one in advance. Pattern ones aren't too dear but genuine Mazda ones are about £30.00.
Get some decent oil too, Millers Millermatic ATF DM
