Central locking
				pistonbroke
Central locking
Does anyone know whether there is a relay or fuse controlling the central locking? The driver's door works perfectly, but the sliding and passenger doors don't work all of a sudden. One minute they were ok, then they stopped for no apparent reason. If there is a fuse or relay, does anyone know where it/they are located? ItOs amazing how  much you miss stuff like that when suddenly it stops working.
						Re: Central locking
There's been a lot of talk on here lately of the loom degrading and snapping where it bends coming out of the drivers door. It isn't something like that is it?
						Re: Central locking
Agree its most likely where the loom passes from the pillar into the door, simple fix.
				the.sasquatch
Re: Central locking
I think there is a fuse, can't remember which one though. Mine stopped working when i blew the fuse to the leisure battery as someone has wired them up to that. If you have a leisure battery it might be worth checking the wiring from that.
						- the1andonly
 - Tribal Elder
Re: Central locking
Central locking is fuse 4 (30A) internal fusebox
top row 4th from left
				pistonbroke
Re: Central locking
Thanks guys. It's not the first time it's happened. The loom at that point has always felt tight and under stress, though the central locking and leccy window wires seem worst affected. I re-made those off with bullet connectors and ended up losing both. Doh! Will try the fuse as suggested, but don't understand why driver's door works but the others don't. Will have more of a poke about.
						Re: Central locking
Is the driver's door just operating from the key, or does the solenoid 'Clunk' but other locks not operate?
Edit: Bear in mind the N/S and side/rear doors do not operate the central locking.
				pistonbroke
Re: Central locking
Thanks again guys, esp for the directions to the fuse. I took it out and was intact. Cleaned and replaced it with a bit of a jiggle and, hey presto, central locking. I should have said originally that my c/l was retro-fitted so that all doors and the tailgate operate remotely.
						Re: Central locking
You say your central locking was retro fitted - what make/model is it? I have a Cobra 4100 that was fitted before I bought my Bongo, and recently the remote central locking has stopped working (although it works when putting the key in the driver's door, and it arms/disarms the alarm).pistonbroke wrote:Thanks again guys, esp for the directions to the fuse. I took it out and was intact. Cleaned and replaced it with a bit of a jiggle and, hey presto, central locking. I should have said originally that my c/l was retro-fitted so that all doors and the tailgate operate remotely.
				Mark Elvin
 - Tribal Elder
Re: Central locking
I've been wondering about a "slow" relay on our central locking. Some days when I unlock, it takes a couple of seconds for the rest of the locks to pop up, other days it's instantaneous.
						- helen&tony
Re: Central locking
Mark...
That'll be the actuator, rather than the relay...mine does it when it's cold!
									Mark...
				Mark Elvin
 - Tribal Elder
Re: Central locking
It's all locks though, not just the one. Also it's 28c here at the moment, not not really cold.helen&tony wrote:Hi
Mark...
- helen&tony
Re: Central locking
Mike...
It was 38 C. here t'other day...the locks worked pretty quick!...
 ...seriously, I think mine does tend to work better with a fully charged battery, and on a warm day...I may whip the door card off again and see if I can spruce it up a bit inside...it may just need the actuator rod bending / tweaking, as the button does rub a bit!
									Mike...
