Bleeding hell , please help
Hi all and thanks
Right I had a slight weep on the colorant pipe work at the T piece under driver seat to rear heater
I have cut this out and repaired
I gave the system a good flush out with the hose
Filled with new antifreeze g12 red/pink 6 litres ,got up to temp see sawed etc etc etc
Watched vids over and over
This was yesterday , when I travelled home after a journey of 15 miles
My bongo( diesel ) was running hotter than usual , on my head temp display 90-92c rather than 82-84 like before???
So I was not happy
Right so tonight I have given the bleeding another go
Sometimes when I was reving engine during bleeding the water in the funnel went Up ???
I took it for a run it was sitting at 90c when bleeding (headtemp) went and put me foot down on dual carriage way, temp dropped to 84 going hard, I started to smile
Thought I would drive back thro town temp went up to 90c usually at 84 86 ish
When at a stand still hea e went up to 91c
Now it never used increase in traffic to that high a temp
Advice good or bad welcome
Do you think I need to do more bleeding
I'm a plumber and have been sorting air locks in central heating systems for 20 odd years
But I can get no more air out the bongo
Never seemed to get any big burps
If I squeeze all hoses water level moves in funnel and header tank
Help please
Goingdevon in 2 weeks with caravan on back
Could do with out this
Cheers gasy
So I was not happy
Help please
Cheers gasy
Re: Bleeding hell , please help
How thoroughly did you flush the system and which pipes were disconnected and used for reverse flushing? Any sign of a frothy substance in the header tank? Reason for asking is that I recently changed antifreeze types and it took best part of an hour with a hosepipe to get it to the point where there was no blue tinge from the old stuff. That was using four different points to get water in and out.
Yes I changed from green to red
I flushed thro all 3 tee outlets under seat
Through rad top
Through vent pipe and header tank
Filled bongo with just water ran up to temp drained and flushed again from all points mentioned above again
Filled up with water ran and ran and flushed again
This took well over 2 hours and there was no tinge of blue / green left
No froth
Just small particles out after flush not much to worry about looked like abit of sand
Through rad top
No froth
after the stat opens and the bongo is revved the funnel does fill. its only before the stat opens that the funnel empties.
it sounds like you may have air in one of the heaters or poor flow at least, check the in and out temps on the pipes when hot. did you check the temps of the heaters during bleeding, this can give clues while the bleeding is going on.
Yes both heaters were blowing hot
The bottom hose to rad was hot
I don't know what to do next
I will take it for another run tomorrow after work and maybe bleed again?
I'm thinking poor circulation
But inside of pipes were lovely and clean
Less than a teaspoon of sand like particles came out when flushing
- haydn callow
Perhaps the green coolant was more efficient at transferring heat.....
Ithe green was definitely a stronger colour
Don't know if that means a stronger mix
I added 6 litres of red
But I did drop funnel twice
And added more water
Tank did overflow a couple of times
And added more water only less than a litre each time
Maybe my red is now a week mix
Will run it again tomorrow and watch temps
They are a constant set of temp readings
And always same amount above old readings
Temp does drop on a fast run on dual carriage way
Just rises higher than old on standstill
Could be a weak / poor quality antifreeze
Hi again
Right I've taken it for a run again
Still the same I'm a present bleeding it again
Seems ok on a fast run sits at 84-86c head temp
But in traffic goes up to 90c it never used to do this
Have drained header and got another 1 litre of red in it
So strength should be good
Did squeeze big hose to top rad and see a bubble go into header
But can get no bubbles at vent pipe or anymore bubbles
Any advice
CHEERS gasy
Any advice
CHEERS gasy
- haydn callow
Sounds o.k. To me...90 in traffic is good....upto 95 o.k
Right just got 2 small bubbles ( I've farted more in church )up into header tank now at 88c in traffic
I'm getting happier
Gonna bleed again tomorrow
Never had an air lock in Central heating/ hot water system in a house beat me
I will win
Thank you Haydn and all
I'm getting happier
I will win
Jim the Box
- Tribal Elder
Mine sits at 84'c normal conditions 92'c highest it has ever gone in traffic. Haydn's alarm is set at 93'c just in case.
"Today's rain is tomorrow's Whisky"
- haydn callow
If you stop for 10 mins....doesn't it alarm when you start again....??Jim the Box wrote:Mine sits at 84'c normal conditions 92'c highest it has ever gone in traffic. Haydn's alarm is set at 93'c just in case.
Hmm, mine has never wavered from the range 92-98. The alarm is set to 105, as in traffic will hit 100 on occasion. I've noticed on a few threads, mine does seem to be hotter than most. (4wd diesel)
What colour / age is your antifreeze roo
Where is your temp sensor fitted
There does seem to be a temp range from 80c to low 90c with different bongos
