coolant alarm
khisanth
coolant alarm
Post by khisanth » Tue Jul 08, 2014 8:54 pm
I have been reading that its advisable to have a coolant alarm fitted. How do i tell if one is fitted and if no fitted how difficult is it to fit one
winchman
Re: coolant alarm
Post by winchman » Tue Jul 08, 2014 9:19 pm
Post a picture of the coolant bottle thingy under the bonnet.
The good ones bleep for a couple of seconds during a self test when you start the engine.
Heres the best place to buy them
http://www.coolantalarm.co.uk/shop/index.php
Its very easy to fit, loads of info on here and the telephone support is also good with the above company, the owner comes on here and will no doubt be along in a moment to help.
If you are not good at DIY wheel quick in Wigan will fit one cheaply and properly
haydn callow
Re: coolant alarm
Post by haydn callow » Tue Jul 08, 2014 11:11 pm
If you have a coolant alarm fitted you will:-
1...have a red LED in one of the switch blanks with a low coolant sticker around it.
2...the LED will flash and you will hear a bleep when you turn the ignition key.
3... Look at the expansion tank under the bonnet, there will be a screw between the full/low marks with a wire running from it.
They are very easy to fit and ours come with everything you will need including instructions.
Also BMW Clocks
