My Bongo has developed a small leak coming from a pipe which is located on the drivers side of the van and approximately half way between the front and rear wheels. The colour of the leaky stuff seems to be a blue-ish/green-ish tinge which would seem to rule out engine oil and brake fluid. Its slightly sticky and viscous. Its dripping from a joint in a pipe which is insulated.
I'm hoping there is a piccy link below.
I've just had the air-con checked and refilled. I can't imagine that is causing the problems as no leaks or loss of pressure were registered when the air-con was tested. But thought i'd mention it just in case!!!
http://instagram.com/p/qE3CSEj3AS/
