been trying to diagnose a loss of power I've had recently...I'm hoping it was just gunge in the fuel strainer in the tank which I've now cleared, along with crud in the fuel filter which I'm now replaced..along with crud in the Banjo..which I've now cleared
ABout to take it out for a drive but thought I'd check for fault codes and have a code 26 which isn't in my service manual although http://www.philmcfadden.co.uk/MazdaDiagnosticBox.htm suggests it's a Solenoid Valve (Purge Control). I'm not sure if that website has the correct codes and wondered if anyone could confirm and explain what/where the valve is (or what it might be called in the service manual)...
It's a '95 automatice without cold start system..I've blanked the EGR with plates and am running on 50% WVO...
hopefully the banjo was the problem and I'll be able to make the Bash at the weekend..otherwise I'm a bit worried about the long drive given I couldn't get above 60 on Sat...off to test drive now...
Ant.
