Hi all,
Wondering if you could help with the following.  I had water dripping out of a join/weld on the underside, level with the rear edge of the drivers door this morning.  It was clear water no additives, the bongo hasn't overheated etc.  It created a reasonable size puddle as well as significant marital stress as my wife tried to drive it to work.
It was on hte off side near the part of the chasis which has various hoses going into a box shape area.  Is it something to do with the aircon?  Should I be concerned?
						water issue
Re: water issue
Sounds like air con but needs checking to make sure
Re: water issue
is it leaking at the point marked with a large Z in the diagram below. its the T piece for the rear heater supply. if yes do not drive the motor.
the drain from the aircon comes out half way along the heater box, near the pipes in and out, these are farther back than the door edge.
Re: water issue
The leak has stopped. There seems to have been no drop in radiator fluid, or rise in temperature. The mechanic I use had a look and said it was coming out of an 'umbrella valve'?? He has some limited experience with Bongos! Is there such a thing?
I couldn't see if it was leaking from hose pipes as it was oozing through a gap in a welded area.
Any other recommendations or thoughts.
