Broken tyre valve stem
the1andonly
Post by the1andonly » Sat Apr 05, 2014 6:17 pm
I was just checking tyre pressures when the tyre valve broke off just bellow the threads. now the bongo has alloys. No tyre place open at 4:30 on a saturday had one. special Japanese ones?. Any clue as to what national chains that my be open tomorrow that have been known to stock them? Is it something so rare that I need to carry a spare?
Re: Broken tyre valve stem
Post by Bob » Sat Apr 05, 2014 6:26 pm
There should be some tyre depots open near you, I can't think a valve should be too rare, but good luck. :)
https://www.google.co.uk/#q=tyre+depts+northampton
the1andonly
Post by the1andonly » Sat Apr 05, 2014 6:39 pm
Just read this
http://www.igmaynard.co.uk/bongo/forum/ ... ve&start=0
could be more difficult to find than first expected.
at least I've got it in my hand the tyres off.
threaded type m6 into wheel approx 30mm to shoulder approx 45mm total length.
no id visible
winchman
Post by winchman » Sat Apr 05, 2014 6:50 pm
If you get stuck I think I have a spare
the1andonly
Post by the1andonly » Sat Apr 05, 2014 8:24 pm
Thanks for the offer but If i cant sort it tomorrow, i will be in cardiff on monday and will pop into Sardis Rd tyres Pontypridd where I had the tyres fitted last year
rita
Post by rita » Sun Apr 06, 2014 3:16 pm
Is this the Type of valve you are looking for..
http://shop.mwsint.com/product_details.asp?id=712
This is the first type of valve to be used when tubeless tyres where introduced, then they started to use the rubber ones.
Just a bit of useless information. :)
the1andonly
Re: Brr oken tyre valve stem
Post by the1andonly » Sun Apr 06, 2014 10:22 pm
Thanks Rita
simular but not the same
mine has the screw in part a smaller diameter m6 the item you show has approx m8 the screw end being larger than the valve end.
currently running on my spare and had a fit when i run over a bottle of vodka whilst parking.
demm to be having grief with hotel wifi so time to send
rita
Post by rita » Mon Apr 07, 2014 8:01 am
No problem, it was the Type of valve that I was referring, I do not know the actual size on your alloys, they call me rita not mystic Meg.
:lol: :lol:
Does this help
http://www.ebay.co.uk/itm/like/12090249 ... =95&ff19=0
the1andonly
Post by the1andonly » Mon Apr 07, 2014 9:38 am
thanks Mystic rita
2 bought
they call me al
how does the nexxt line go
the1andonly
Post by the1andonly » Tue Apr 08, 2014 10:32 pm
This was one problem i wasn't expecting and due to the lack of knowledge/ stock in mainstream tyre dealers in Northampton and Cardiff I will carry a spare along with the fuses. Phoned Rob at the famous Sardis RD tyres Pontypridd "need to see it" so 10 miles later: yes hens teeth I had some in the past on special order, no haven't got any left.
Any one with alloy wheels on their Bongo from import should concider indentifying the valve at a tyre change and get a spare, not quite hens teeth but as good as in the mainstream.
Thanks to winchman for the offer of his spare and to Betty (i mean mystic Rita) for a top Ebay link. Parts ordered yesterday about 9 am delivered today (7 quid the pair inc delivery).
will need to do a trial fit, overall length of new 40mm
winchman
Post by winchman » Wed Apr 09, 2014 4:55 am
Glad you are sorted
I bought some nice 17" alloys so as my 15" were tatty I weighed them in but for some reason took the valves off.
I will check my new alloys and carry a spare in the box of bits in case of a problem
the1andonly
Post by the1andonly » Fri Apr 11, 2014 11:07 pm
Just to close this thread
my original valve stem was 45mm long
the part from nuts4wheels on ebay is 40mm long
http://www.ebay.co.uk/itm/1-X-6mm-Tire- ... 4897.l5668
has been successfully fitted (with tyre)
anybody know what a split infinitive is?
Simon Jones
Post by Simon Jones » Fri Apr 11, 2014 11:23 pm
It's when an adverb or adverbial phrase is placed between to and the verb. Most famous example is "to boldly go" which should really be "to go boldly".
