Locating a Particulate Filter
MX5Marc
Post by MX5Marc » Sun Mar 02, 2014 1:20 pm
Has anyone got a diagram as to where I can locate my EGR valve and Particulate Filter on a 1999 2.5TD?
I'm suspecting that mine need a good clean but am not sure where to find them!
Marc
scanner
Re: Locating a Particulate Filter
Post by scanner » Sun Mar 02, 2014 1:48 pm
What particulate filter? :?
Simon Jones
Post by Simon Jones » Sun Mar 02, 2014 2:08 pm
EGR valve can just be seen labelled 17 on this photo: http://mazdabongo.wikispaces.com/Parts
There is no DPF or cat fitted to diesel Bongos, so don't look too hard :)
teenmal
Post by teenmal » Sun Mar 02, 2014 2:34 pm
Simon Jones wrote:EGR valve can just be seen labelled 17 on this photo: http://mazdabongo.wikispaces.com/Parts
17 is the nrv for the vac valve.
This is the EGR valve 20-300,just follow the pipe from the inlet manifold and you will find it.
http://lushprojects.com/bongopartsmk2/c ... no=.html#7
MX5Marc
Post by MX5Marc » Mon Mar 03, 2014 11:31 am
:lol: Thanks for the help guys.
Glad I didn't spend too long looking!
In the majority of cases I flip the seat back, and just stare blankly at a muddle of metal, plastic and wires! :?
Off outside to try and get at the EGR Valve now.
I removed the pipe and gave that a good clean (there was a lot of build up in it).
The blanking plates have been removed, so hopefully with the EGR cleaned - I might have a happy engine again! [-o<
scanner
Post by scanner » Mon Mar 03, 2014 11:43 am
MX5Marc wrote::lol: Thanks for the help guys.
Blanking plates?
If it had blanking plates fitted it wouldn't have needed cleaning - that's what blanking plates are for, to remove the need for cleaning.
MX5Marc
Post by MX5Marc » Mon Mar 03, 2014 12:20 pm
I did have blanking plates fitted - but the ECU is still reporting issues with EGR airflow.
My mechanic advised to either clean or replace the EGR valve.
I've been out to have a look for it - and the lushprojects diagram looks different to my engine. I take it that was for the older style Bongo?
Mine is a 1999 fly-by wire (which is why it's proving such an expensive pain in the wotsit!)
https://onedrive.live.com/embed?cid=CFC ... F3E2E55xgA
https://onedrive.live.com/embed?cid=CFC ... 4Rwi59oa1s
https://onedrive.live.com/embed?cid=CFC ... SvzCbUvDiY
teenmal
Post by teenmal » Mon Mar 03, 2014 1:44 pm
That is a problem when people fit blanking plates and don't decoke the pipes and manifold.
Does this help....
http://lushprojects.com/bongopartsmk2/c ... o=.html#14
MX5Marc
Post by MX5Marc » Mon Mar 03, 2014 3:06 pm
Thanks teenmal.
I'm still struggling to see it.
I assume it's not showing in the 3 photos I posted?
If I'm viewing the diagram correctly it should be on the right (dashboard end) of the EGR pipe...
All that appears to be connected to is the metal elbow to the inlet pipe.
Should I then be looking at the other end of the EGR pipe? Although that looks to be very difficult to get to.
teenmal
Post by teenmal » Tue Mar 04, 2014 9:52 am
Yes other end. Taking off the top engine panel cover will give you better access.
