Overheated
egor617
Overheated
Post by egor617 » Sun Feb 16, 2014 2:01 pm
Took our mazda bongo to a local bongo friendly garage on friday to have a fuel leak sorted, all the coolant hoses replaced and a service.
Picked it up friday and drove home 5 miles stop start traffic no problems.
Took it out yesterday and within a mile the temp gauge started rising limped home and there is no coolant in the expansion tank, plus it's still leaking fuel.
Now when i phone the garage up what should i be looking at them doing to resolve this?
My problem is the engine is aluminium so overheating often leads to cracked heads also i don't want to start/drive it to the garage as there could be a airlock and lead to more damamge to the engine.
What really Kisses me off is we decided to replace all the rubber hoses to prevent it overheating and that's what happened. frown
the laird
Re: Bugger overheated
Post by the laird » Sun Feb 16, 2014 2:13 pm
They are obliged to collect veh (as you will tell them it can't be driven)and you are wanting these faults rectified at no cost as you paid in good faith to have it repaired ,it's now come out in a worse state than it was! Sounds like they've not bled the coolant system correctly if there are no visible coolant leakages,fuel side of things what did they do to (rectify)fuel loss as it seams they ain't sorted.if they had gave it a good test after they sorted these faults may have been obvious to them! Did you take a note or or the invoice is there a mileage in and mileage out?
Dr Fingers
Post by Dr Fingers » Sun Feb 16, 2014 2:16 pm
Looks like a flat loader needed, then it's down to them. Are they your regular people? They should look after you.poss sounds like not been bled proper :(
Derek
egor617
Post by egor617 » Sun Feb 16, 2014 2:21 pm
Re the fuel leak the injector was rebuilt 2 years ago, had a fuel leak oct and was diagnosed as split hose , and the latest leak was supposed to be split hose again.
Re bleeding this garage are quite well known here for being bongo savy so presumed they know what there doing, and it was the garage which suggested changing the hoses as it's a known weak point with the age bongos are.
the laird
Post by the laird » Sun Feb 16, 2014 2:43 pm
Last man frees all type of thing on this one,reiterate NOT BLED correctly by sounds ,was it road tested after they carried out repairs?
egor617
Post by egor617 » Sun Feb 16, 2014 3:01 pm
the laird wrote:Last man frees all type of thing on this one,reiterate NOT BLED correctly by sounds ,was it road tested after they carried out repairs?
The invoice just states :
coolant hoses replaced & system refilled with long life coolant , run up & check circulation all ok
the laird
Post by the laird » Sun Feb 16, 2014 3:08 pm
Still down to them I feel ,good luck and keep usosted as to how you get on,mind don't drive until it's rectified
egor617
Post by egor617 » Sun Feb 16, 2014 3:16 pm
the laird wrote:Still down to them I feel ,good luck and keep usosted as to how you get on,mind don't drive until it's rectified
Will do .
So when i phone them should i just explain the above and wait and see what they offer?
What i fear is a catch 22 situation where they say bring it to us and we'll look at it, although they do have a good reputation in this town and have been going 20+ years and do quite a few bongos, it was them who said they do loads of services/hose changes every march where people get them serviced ready for the summer camping trips.
the laird
Post by the laird » Sun Feb 16, 2014 3:34 pm
Put the ball back into their court as they will know as any specialist bongo repairer you don't drive an overheating bongo! You drove it there in good faith it's their prob now to transport it to rectify a fault you didn't have when you took it in good faith for service and repairs also hose changes that they advised
Good luck
Simon Jones
Post by Simon Jones » Sun Feb 16, 2014 3:55 pm
Assuming it was bled correctly then it could be a faulty/poor fitting hose, or even one of the steel pipes that has sprung a leak since being disturbed. Did you have a low coolant alarm fitted? If not, it would be well worth doing regardless of how new the hoses are.
Post by Northern Bongolow » Sun Feb 16, 2014 6:13 pm
ask them if they pressure tested the system after they fitted the new hoses. before they ran it up checked the circulation of coolant.
egor617
Re: Overheated
Post by egor617 » Sun Feb 16, 2014 8:15 pm
Thanks for the help everyone.
My worry is if the garage sort it how do i know the head hasn't warped and in no time i'll be back to square one.
What sort of checks should i expect the garage to be doing other than pressure testing?
Re: Overheated
Post by Doone » Mon Feb 17, 2014 12:59 pm
If it was mine, I'd have a look to see where the coolant has leaked from, before it goes back to your garage.
And don't drive it anywhere.
egor617
Re: Overheated
Post by egor617 » Mon Feb 17, 2014 4:00 pm
Update-
Garage came to us with the intention of bleeding it on the drive and driving it to there garage, changed there mind and put it on a low loader and took it away.
Seemed quite genuine on the phone that they wanted to find out why it had overheated and sort it.
egor617
Re: Overheated
Post by egor617 » Mon Feb 17, 2014 6:32 pm
egor617 wrote:Update-
Garage phoned, the new bottom hose had a split in it, new one being put on tomorrow. Been pressure tested and everything fine, head gasket and head all seem fine.
Anything else i should be asking to be checked?
