waterpipes
grizzlya58
- Junior Bongonaut
waterpipes
hi.can anybody tell me if they have renewed water pipes on the bongo, I had a look under mine around the gearbox area and noticed a few rusty pipes, some short ones and long. they seem pretty bad ,so I was wanting to renew them before I go galavanting this year,can you buy them, or can they be made up from something like hydraulic pipe, any help would be great thanks,
Re: waterpipes
Try the Bongo Shop - see top right corner of this page look under coolant ! You don't say the vehicle type so .... but yes if you do a search others have the same problem and have replaced / repaired.
grizzlya58
- Junior Bongonaut
Re: waterpipes
thankyou,
I will have a look .I just seen the one metal pipe in the shop,but still not sure what the ones are that are rusty, I would attempt myself if I knew what size of pipe and what kind, aiso a few beers. just for a steady hand,
Re: waterpipes
If you do this yourself be sure to bleed it properly.
This isn't an unusual repair so any Bongo Friendly garage can do it.
Re: waterpipes
I've got some others as well, email me for details [email protected]. But take a look at the Hoses factsheet in the members area so you can find the part numbers of the ones you need.grizzlya58 wrote:I just seen the one metal pipe in the shop,but still not sure what the ones are that are rusty,
Re: waterpipes
it sounds like its this pipe. click on the link here and have a read.
http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=58378
