Airlock
Eric
Airlock
Post by Eric » Mon Feb 03, 2014 9:29 pm
I have late 1999 V6 Bongo and recently had the coolant changed but after a short while the front heater stopped working.I think there is an airlock in the heater coil can anyone tell me how access and bleed this item.
e: Airlock
Post by Bob » Mon Feb 03, 2014 9:39 pm
There's about 3 Youtube videos, plus a Fact Sheet in the Member's area.
Bleeding is vital.
https://www.google.co.uk/#q=youtube+ble ... azda+bongo
Simon Jones
Re: Airlock
Post by Simon Jones » Mon Feb 03, 2014 10:04 pm
That's right, you must bleed the V6 as you would a diesel engine. I believe only the 2.0 is self-bleeding.
Eric
Re: Airlock
Post by Eric » Fri Feb 07, 2014 10:11 pm
I have seen the video,s on how to bleed the coolant system and this would have been fine on my first bongo,a diesel.
however they do no apply to my present Bongo.Its V6 Petrol engine and there is no bleed tube therefor I can only surmise that this is a self bleeding system. It is 1999 V6 petrol engine with a autogas conversion,(it is a special edition
but I can nott see that making any difference to the cooling system) Regards Eric
Re: Airlock
Post by g8dhe » Fri Feb 07, 2014 10:35 pm
My V6 has the standard bleed tube !
Re: Airlock
Post by Bob » Fri Feb 07, 2014 10:52 pm
I suspect if it doesn't have a bleed tube it should have.
Only the 2ltr is self bleeding.
Re: Airlock
Post by Northern Bongolow » Fri Feb 07, 2014 11:01 pm
Simon Jones
Re: Airlock
Post by Simon Jones » Sat Feb 08, 2014 12:04 pm
The bleed pipe can be seen here running top left to bottom right with the bung in the end. If you don't have one, you should have:
Eric
Re: Airlock
Post by Eric » Tue Mar 25, 2014 11:50 am
Hi Folks.Ifound the airbleed tube(it was under all the pipes and other equipement that constitute the autogas conversion equipement ) My heater is now working but is not seeming to put out as much heat as it used to,
I have been told that in some vehicles the heater will not work unless the aircon is fully charged, can anybody tell me if this applies to the Bongo.Also is there a valve or solenoid in the heater supply line and if so where.
Best Regards Eric
wonkanoby
Re: Airlock
Post by wonkanoby » Tue Mar 25, 2014 11:55 am
no
it might help if you back flush it as they can become blocked
you might be surprised at the crud in it
rita
Re: Airlock
Post by rita » Tue Mar 25, 2014 6:12 pm
Owing to the fact that the thermostat controls the engine temperature I would think its worth investigating, it also determines the heater function.
These vehicles do not have any heater water control valves its a full flow constant system.
haydn callow
Re: Airlock
Post by haydn callow » Tue Mar 25, 2014 8:46 pm
The heater system bypasses the thermostat.
http://www.coolantalarm.co.uk
Also BMW Clocks
