Juddering
Juddering
I hope that someone can help me with some suggestions or advice when I am driving my bongo at between 55mph and 60mph I get a juddering which seems to be coming from the front of the vehicle the steering wheel also vibrates then when I reduce speed it disappears but comes back at 40mph can anyone suggest what it could be please.
Kind regards
Steve Powys
Kind regards
Steve Powys
Re: Juddering
Could be that your wheels are out of balance.
Might be worth having them done at your local tyre depot as it doesn't cost a lot to have done
Re: Juddering
That's where I would start.
Re: Juddering
Thanks to you both I will try that first
cheers
Steve
Powys
cheers
Steve
Powys
Re: Juddering
Have you got genuine Mazda alloys or aftermarket ones? I've had both and even the proper fitting Mazda wheels when correctly balanced can give a bit of a wobble over 60 mph. Aftermarket wheels tend to be universal fit and will require spigot rings if the bore diameter is greater than the spigot on the hub.
Re: Juddering
The first thing, make sure that the wheel nuts are tight then get the vehicle to a garage. Don't take risks with this type of fault..
- daveblueozzie
Re: Juddering
Also make sure you have the right wheel nuts as well, normal bongo wheel nuts are not suitable for alloy wheels.
Lost without my Bongo.
Re: Juddering
Is it a f/w/drive?if balance and wheels are ok it may be a drive shaft fault or prop shaft fault
Also check there are no brakes staying on?
Re: Juddering
Hi all
Thanks for the replies if it is drive shaft or prop shaft is that expensive
steve
steve
Re: Juddering
I had same problem, spigot rings solved it for me. Steering wheel shaking was bad around 65mph.
I ordered a set from eBay, took a bit of a chance on the size - they were described as for a Bongo and I know the inside was the required diameter - I just didn't know the exact inside dia of the alloy wheel. Anyway, I think they were £5 delivered and fitted perfectly.
Re: Juddering
It depends if it's a full drive shaft you fit or a joint.you can replace joints on prop shafts but there are suppliers who will replace or refurb your prop ,places vary in price got to shop about
Re: Juddering
after checking the tyers mine ended up being the u joint
Re: Juddering
Thanks for the reply I have now sorted it out it was the tyres needed balancing thanks again for the reply.
Steve Wales
Steve Wales
