Any top tips to spruce this up, do I need special plastic paint or can I get away with standard?
Does the badge come off?
Pics if you have them would be a bonus.
Moderator: Ian
I did likewise, though used a Swan & Morton modelling knife to mask only the chrome badge logo. Also, I used spray on plastic primer (after wet and dry sanding the grille) then a silver (cellulose car paint) that took my fancy. The car looked hugely improved once job donejimmo62 wrote:Sorry away from home at the moment so no photos...
I sprayed mine with Simoniz Acrylic car paint - Satin Black. It has come out really nicely, retaining the slight surface texture on the grillle but covering nicely. Before starting the grille was a muddy grey colour - I think it may originally have been chrome but that has long since gone!.
I degreased it thoroughly and masked off the whole badge with masking tape. Lots of thin coats of paint later it was looking pretty nice. I sprayed from the back first to get all the surfaces, then I did the front. I removed the masking on the badge and used a small paintbrush to fill in the middle of the badge (sprayed some paint into a small container to do this) which took just 2 coats.
I'm no expert in paint spraying but this is a straightforward job.
I think you can get the badge off but I'm not sure it's worth the bother unless you are after absolute perfection.....which on a 20 year old car didn't seem a problem.....
Good tip. Whatever you do, do not spray car paint onto plastic grille without using plastic primer spray first, or you may get a crazing reaction with the plastic grille.Gasy wrote:There is a bloke on here who is getting into transfer dipping
Fancy a fancy grill he's your man to speak to
Think he's cabte
