Flashing glow plug light
uncle monty
Post by uncle monty » Tue Dec 31, 2013 5:44 pm
Merry Christmas fellow Bongo lovers, and a happy New year to you all :) Took the Bongo on a run earlier and the glow plug light started flashing and the radio went off. There was a lot of surface water which I guess was to blame. Has anyone else had this issue? Which relay/contact etc do I need to zap with the wd40 to prevent it happening again?
Re: Flashing glow plug light
Post by g8dhe » Tue Dec 31, 2013 6:45 pm
If the Radio went off and the Glow plug light started flashing then suspect either of these fuses;
or
Simon Jones
Post by Simon Jones » Tue Dec 31, 2013 6:47 pm
If it's not a fuse, then have a read of the diagnostic factsheet:
http://www.igmaynard.co.uk/bongo/member ... ostics.pdf
uncle monty
Post by uncle monty » Sat Jan 11, 2014 5:33 pm
Thanks guys. The fuse shown top left is missing, what does this one do? Not noticed anything not working, just intermittent fault with the stereo?
Simon Jones
Post by Simon Jones » Sat Jan 11, 2014 5:59 pm
uncle monty
Post by uncle monty » Sat Jan 11, 2014 6:27 pm
Great thanks..... any ideas what that means in terms of equipment/functionality etc? Have not noticed anything not working...?
wonkanoby
Post by wonkanoby » Sat Jan 11, 2014 7:20 pm
Do you have a leisure battery set up
Simon Jones
Post by Simon Jones » Sat Jan 11, 2014 7:23 pm
There's a list here: http://www.igmaynard.co.uk/bongo/forum/ ... lit=Fuse+1
Sounds like someone may have connected it to the leisure battery (if you have one) to run the interior lights which could cause issues with ECU should the LB battery drop too much.
uncle monty
Post by uncle monty » Sat Jan 11, 2014 7:32 pm
Hmmm, I do have a leisure battery with dual charge circuit, but i am not 100% convinced it is in top shape. The interior lights are very dull. Tried charging the LB but made no difference, i think it is a maintenance free one. It has Japanese writing all over, think it may be the original Battery so is now 18 years old. Sorry for my ignorance but should I replace the 10A fuse in fuse 1 slot or has it been rewired into the LB circuit?
Simon Jones
Post by Simon Jones » Sat Jan 11, 2014 7:42 pm
If the interior lights are running dimly with no fuse, then it would suggest they have been wired to the LB. If you refit fuse 1 it will connect the two batteries in parallel which will probably blow the fuse. If you have a multimeter, check the voltage across the LB with engine off (should be around 12v) and then start the engine and check after a minute or so and it should be around 13 - 14v. If it's not charging then, locate the fuse for the split charge as that may have blown. If the LB voltage is low and not being charged, that would explain the flashing glow plug light and you may start to experience issues with engine and gearbox ultimately resulting in a non-running Bongo :(.
uncle monty
Post by uncle monty » Sat Jan 11, 2014 7:55 pm
Crap that doesn't sound good :( What kind of issues? She runs a treat at the moment...? Flashing glow plug light was a one off and happened just after we had driven through a large puddle.
Simon Jones
Post by Simon Jones » Sat Jan 11, 2014 8:09 pm
If the engine and gearbox ECU voltage drops too low, the engine / gearbox won't function. If the light has gone away now then it's probably fine if every thing else seems to be in order. Out of interest, is it the rear fluorescent lamp in the roof that is dim? If so, it could be a simple as fitting a new bulb as the output does drop as it ages.
uncle monty
Post by uncle monty » Sat Jan 11, 2014 8:32 pm
Yes that's the one. It comes on but is very dim. The courtesy lights in the front are fine. I have a mutimeter i borrowed from work, will have a play tomorrow and check out the voltage etc. Once I work out how to use the damn thing..! Thanks for your help, will let you know how I get on.
Post by Northern Bongolow » Sat Jan 11, 2014 10:19 pm
sounds like your issues are linked to your other thread, melted fuse box...
