Slight 'squeal' on full steering lock
TonyW
Post by TonyW » Mon Oct 14, 2013 10:59 pm
The topic title says it all really.
With our previous cars (all a lot younger than our 'new' 1995 Bongo) we have relied on mechanics when something has gone wrong. This time we are going to try and do much of the work ourselves ...... within reason.
So, on full right lock we get a slight metallic squeal .... as I've said before, I should probably know what this is and a little voice in my head suggests something to do with a steering bush???
Anyone?
Thanks.
Tony.
windywatson
Re: Slight 'squeal' on full steering lock
Post by windywatson » Wed Oct 16, 2013 6:01 pm
Hi, when in full lock, the power steering is at its heaviest load. I would suggest that the squeal is one of 2 things. Firstly the drive belt is in need of tensioning as it sounds as though it is the belt starting to slip and squeal under load. Secondly that it could be the bearings in the power steering pump, although I would have expected that they would be making the noise all of the time if it was bearings.
I would check the drive belt tension in the first instant as I would guess that is it.
Windy-Watson
2001 V6 Tin Top
Post by Northern Bongolow » Wed Oct 16, 2013 7:43 pm
try steering rack/pump recon fluid it may help.
http://lushprojects.com/bongopartsmk2/c ... 2of02.html
or it could be the rack spindle valve.
http://lushprojects.com/bongopartsmk2/c ... o=.html#20
rita
Post by rita » Thu Oct 17, 2013 10:11 am
windywatson wrote:Hi, when in full lock, the power steering is at its heaviest load. I would suggest that the squeal is one of 2 things. Firstly the drive belt is in need of tensioning as it sounds as though it is the belt starting to slip and squeal under load. Secondly that it could be the bearings in the power steering pump, although I would have expected that they would be making the noise all of the time if it was bearings.
Just in case they start hunting for a PS belt this vehicle doesn't have one. :)
