outwell country road attatchment help needed
Moderator: Muzorewa
Re: outwell country road attatchment help needed
Post by Muzorewa » Wed Aug 28, 2013 11:06 am
I think what seventiesboy means is when you open the casing, you should see a small channel like this (this is an Omnistor so not exactly the same as the YKK)....
Then you get a 3.0m length of the Kador strip (the grey thing in the pic below) that you can trim to length or just leave long, to connect the beading of your driveaway awning to the figure-8, and thence to the casing of your YKK :wink:
bongolou
Post by bongolou » Wed Aug 28, 2013 11:14 am
Ah i will have a look later and take a picture and upload on here. That's a great help seeing your pictures. Do you then wind in the YKK once its connected. This looks a very neat way of attaching the awning so i hope its possible with the YKK.
2002 Bongo V6 Petrol AFT Sunlight Silver Metallic with YKK awning.
seventiesboy
Post by seventiesboy » Wed Aug 28, 2013 11:16 am
That's it :D :D :D
Well done Muz
Buy the kador the length that you need it, run it along the channel, attach the figure of 8, attach the bead on the awning tunnel to the figure of 8 and jobs a good un"
And, yes, wind it back in.
Why?...........Because somebody might wave back.
bongolou
Post by bongolou » Wed Aug 28, 2013 11:28 am
woohoo this sounds perfect ;-) going to buy 3m of kador and i guess 3m of figure of 8 and hope thats the right length not got the awning yet but need to get attachment sorted for when it arrives.
Post by Muzorewa » Wed Aug 28, 2013 11:36 am
Just make sure you get the right one, we got ours from here....
http://www.lightningleisure.com/acatalo ... .html#a110
For the Omnistor we needed the Safari Kador which has a standard bead one side and a smaller bead the other side. From what's posted above it appears you need the Standard Kador, with standard beads both sides.
bongolou
Post by bongolou » Wed Aug 28, 2013 11:43 am
Thanks Maz. Going to check the ykk has the little channel at lunchtime to be sure and post a picture then will order some. Would i require 3m of the kador and 3m of the figure of 8? Or less than that?
Post by Muzorewa » Wed Aug 28, 2013 11:54 am
3.0m is plenty, I got 3.0m and trimmed it to suit. Normally the figure-8 is in shorter lengths although you can get long pieces, but 2 or 3 shorter pieces of figure-8 to make up the required length is fine :wink:
seventiesboy
Post by seventiesboy » Wed Aug 28, 2013 12:20 pm
Pretty sure that the YKK is standard 6mm x 6mm kador unlike the Fiamma.
The length of kador and figure of 8 required is dictated by the length of the channel on the YKK and also the height/width of the awning tunnel. When you get the awning there will be instructions on how to measure the figure of 8 to the right length so that it fits the height of the van, you will understand what I mean when you see it.
3m will be more than long enough, probably more like 2.5m. Measure the channel lenght on the YKK and go from there. Obviously when you fit the kador and close the YKK back up again you are limited to the lenght of that channel.
bongolou
Post by bongolou » Wed Aug 28, 2013 6:36 pm
http://i1332.photobucket.com/albums/w61 ... c3.jpgHere is a picture of the ykk does it look like the kador and figure 8 will work?
Post by Muzorewa » Wed Aug 28, 2013 6:42 pm
Yep, that looks just the job :wink:
bongolou
Post by bongolou » Thu Aug 29, 2013 6:05 am
Excellent news thanks so much for your help guys going to order the kador and figure of 8 now. :D
