My mate recently had a new head on a 95 diesel bongo.
I had a quick nosey and found that there is no bleed hose.
Any idea what has been done and how you bleed it?
Could it be Ford ranger head or newer type?
no bleed hose
no bleed hose
Always be ready for a Top Up!
Re: no bleed hose
the ranger head is the same head as a bongo baz, its just that the fitter has fitted a 2 hose outlet instead of the 3 outlet that takes the bongo bleed hose.
the fitter in question usually fits this outlet baz.
there is a way of modifying the small dia turbo coolant supply hose to fit a bleed pipe into the system if you need to.
Re: no bleed hose
Is it likely the Bongo wasn't bled after the new head fitted?
Re: no bleed hose
I fitted a Ranger head to my Bongo...
I just tee'd off the small 8mm id hose with a brass airline fitting.
Use the same 8mm I.D for bleed hose.
Nice aluminium plug from ebay.
Works a treat.
Works a treat.
Re: no bleed hose
Baz,
I will be at the Looe bash if you want to see this in the flesh as it were.
Re: no bleed hose
vacum bleeding
no bleeding
wish and hope
no bleeding
wish and hope
