Temp gauge normal behaviour
ToolkiT
Post by ToolkiT » Mon Jul 22, 2013 11:02 am
I just bought a Ford Freda. In the paperwork I found the phone number of the owner before the guy I bought it from so I rang him to get a bit of history of the vehicle.
He mentioned he had had some overheating issues but that the guy who bought it from him said he was going to fix that and sell on.
Good news is that the temp gauge shows no overheating and some of the hoses have been replaced so it looks like the work has been done. I drove the Freda home 90 miles on a hot day and it seemed to be fine...
However it does seem to warm up fairly slowly...
The pesimist in me wonders if they have fiddled with the gauge so it is alway showing a lot colder then it actually is.. ie show normal (middle of gauge) temps when it is actually overheating..
Can anybody give me an indication of what is 'normal' given there are know issues with the gauge..
Re: Temp gauge normal behaviour
Post by Muzorewa » Mon Jul 22, 2013 11:14 am
Sounds to me like they've just removed the thermostat :?
A normal gauge sits at 11 o'clock even when overheating. You can mod the gauge so it gives some meaningful readings but most sit at 11 o'clock.
ToolkiT
Post by ToolkiT » Mon Jul 22, 2013 11:17 am
Muzorewa wrote:Sounds to me like they've just removed the thermostat :?
Do you know where that connection is so I can check it out?
ToolkiT
Post by ToolkiT » Mon Jul 22, 2013 12:31 pm
I let the engine iddle for 5-10 minutes and the gauge stayed at:
When I spoke to the original owner he did mention one of the things his mechanic tested was to see if the radiator pipes warm up on both end (which they didn't for him indicating a problem with the head), but for me both pipes eventually warm up, indicating there is flow through the radiator, which is good one would think..
Post by Muzorewa » Mon Jul 22, 2013 12:45 pm
....but the thermostat should stop it allowing water to flow through the radiator until it's warmed up :wink:
ToolkiT
Post by ToolkiT » Mon Jul 22, 2013 12:53 pm
Do you have a diagram for where the thermostat is and how the wiring goes?
(1995 diesel model)
Post by Muzorewa » Mon Jul 22, 2013 1:09 pm
Thermostat is 15-171, you'll see the housing under the passenger seat at the front of the engine. But when you dismantle the housing you'll have to bleed the system again :wink:
No idea on the wiring though
ToolkiT
Post by ToolkiT » Mon Jul 22, 2013 1:18 pm
Muzorewa wrote:Image
Thanks, so no easy way to check if the thermostat is there then..
do we know where the temp sensor is? I noticed a sensor on the drivers side, so assume that is it?
Post by Muzorewa » Mon Jul 22, 2013 1:27 pm
No, not without dismantling the thermostat housing although that's only two bolts. As soon as you disturb it, coolant will hiss everywhere and you'll have allowed air into it so you'll have to bleed it properly.
Get a genuine Mazda thermostat, about £18.00 + VAT.
One of the electrical bods will hopefully be along with the other answers :wink:
ToolkiT
Post by ToolkiT » Mon Jul 22, 2013 1:42 pm
Thanks for the feedback :)
I had another idea: use ODBII diagnostics to read out the water temp....
But it seems the bongo uses a different diagnostics port:
instead of:
So I need to find out if there are any adaptor cables available...
If so I can use that to keep an eye on the water temp..
helen&tony
Post by helen&tony » Mon Jul 22, 2013 1:47 pm
The temperature sensor is on the front of the head, driver's side. Part 6 on this picture:
http://mazdabongo.wikispaces.com/Parts
ToolkiT
Post by ToolkiT » Mon Jul 22, 2013 2:01 pm
helen&tony wrote:Hi
mikeWalsall
Post by mikeWalsall » Mon Jul 22, 2013 2:28 pm
I'm not sure if any one as sussed out a compatible reader .. leads .. software for the Bongo ..
http://www.philmcfadden.co.uk/MazdaDiagnosticBox.htm
Do a 'Search' there are various posts like ...
http://www.igmaynard.co.uk/bongo/forum/ ... mit=Search
wonkanoby
Post by wonkanoby » Mon Jul 22, 2013 2:31 pm
start it up
then feel pipes to front lower radiator
if they get warm then stats open
or has had guts removed
ToolkiT
Post by ToolkiT » Mon Jul 22, 2013 2:37 pm
ToolkiT wrote:Thanks for the feedback :)
instead of:
Found the right cable :)
http://www.ebay.co.uk/itm/Mazda-Ford-Ra ... 1078933970
