changing rear ABS sensors
surfbus78
Post by surfbus78 » Fri Jun 28, 2013 9:19 pm
All,
I've done the diag trick as per http://www.igmaynard.co.uk/bongo/forum/ ... +abs+light to determine why my ABS light is staying on, my light flashes out the code 33 which, according to the link, is "Rear Wheel Sensor" , i've found someone who can supply me a pair of them for £55 , but my question is , how do i fit them, do they unscrew from the axle housing or are they just pushed in?
any hints and tips from anyone who has done this job before?
many thanks in advance
Steve
Wolverhampton
Re: changing rear ABS sensors
Post by Northern Bongolow » Fri Jun 28, 2013 11:17 pm
http://lushprojects.com/bongopartsmk2/c ... 2of02.html
http://lushprojects.com/bongopartsmk2/c ... 1of02.html
nightmare to get out. best to test in situ, then remove when proven faulty, the mounting bolt usually sheers off too. good luck.
D2472
Post by D2472 » Sat Jun 29, 2013 4:37 pm
If the bolt sheers off will the sensor just pull up over the bolt to take it off ?
Post by Northern Bongolow » Sat Jun 29, 2013 7:21 pm
ive only done front.
the fronts are nearly impossible to get out, even without the bolt in place, ive changed the entire swivel rather than just the sensor after wrecking several.
the rears look similarly mounted, but have never tried to remove one. #-o
D2472
Post by D2472 » Sat Jun 29, 2013 9:24 pm
Yes mine is ns front. I've sheered the bolt head off but I still can't get it off. Shall I just change the hub ?
surfbus78
Post by surfbus78 » Sat Jun 29, 2013 10:48 pm
The guy i spoke to, george @ http://www.bongospares.co.uk/ said don't bother trying to remove the fronts, just replace the hub, he sells them as a complete hub.
hopefully my rears will come out okay!! i'll let my mechanic mate do it then he can remove the bolt if it shears.
D2472 wrote:Yes mine is ns front. I've sheered the bolt head off but I still can't get it off. Shall I just change the hub ?
Wolverhampton
